- Jun 7, 2008
- Age
- 58
- North Texas
I like to compare it to a Respirator - they use filters right. Well depending on the filter, one will be harder to breathe through than another. Specifically if I am using a P100 Organic Acid Vapor Cartridge (Filter) it will be harder to breathe through than a N95 Filter because of the density of the filtering media (pleats and tightness of the weave). A P100 would be comparable to the OEM filter in that it has more material to filter out smaller particles. I respirator terms this cartridge is referred to as a HEPA (High Efficiency Particulate Air) cartridge and will filter out 99.97% of particulates down to o.3 microns. The N95 then would be equal to a K&N (need to change mine back LOL) Filter in and has an efficiency of a minimum 95% of the particulates.
Yes this is dealing with breathing protection - but the comparison is similar regarding the amount of air that can be moved in regards to how much power is expended to much said volume of air. Them OEM is more restrictive but provides better protection where as the K&N is less restrictive and less protective . . . just a different approach to it.
Any air filter will do its job. Just a matter of how well it does it. I use to run the K&N filter until I had an oil analysis done and showed high levels of silcon. Swithed to a good old Fram paper and the silcon levels have been dropping since. Now not to say a K&N filter is bad, but if it doesn't serve the purpose. Why use it?
