- May 28, 2021
- Virginia
- 4.0 V6
- Automatic
My 2011 4–door SuperCab has the OEM accessory running boards, which are straight and held with two brackets each. Both have the chrome finish.
The passenger's side board has serious rust, replacements are unavailable new now, and I really don't need either one anyway. I'm thinking about simply removing both boards and their brackets. The boards can be removed from the brackets easily.
Leaving the brackets without the boards could pose a hazard to others because they will then project from the body.
My concern is with removing the brackets from the underside of the truck. Is an impact driver going to be necessary to break the bolts free? Anything I need to watch for? My intent is to remove one bracket at a time and reinstall the bolts before moving to the other bracket on that side. There is no rust or other problems with the body around the brackets.
Thanks.
Thanks.
