Pics of my 95 Ranger Sittin on 38s
95' should have a D35 up front. I'd swap in an explorer 8.8 for strength and disk brakes to stop the bigger meats. Hp doesn't make up for a lack of gearing, put 5.13's in it and the blower, then it'll move good.
-andrew
D35 is a 8.8 right??? Mine is also a 3.0...
My Rear has 3.45 gears.. Dont make a
3.45 gear in a 8.8 do they??
If the do, I would be Happy...
Thanx,
Rob
Lil Ranger
Not a 2wd..
What are you running for hubs then? I see chrome center caps on the front wheels, that's why I asked.
Oh boy.... Dana 28/35's are the front TTB axles found in Rangers/BroncoII/Explorers.
7.5/8.8 are the rear axles, like in your Mustang....
Mustang.. Thanx...
There Manual Lockin Hubs.. Dont see any Names on them..
How can I tell the Difference between a D28 to D35???
Easy way?? Buy Lookin at it??? Like Shaft Thickness???
Thanx,
Rob
Lil Ranger
holy crap...that is awsome looking...but for off road to big and and not enuff umpf.....with a 3.0 and 3.45s you must be burning up your tranny....i have 31s and a 3.73s with a 5 speed and that is as big i will go...but still looks neet
Looks good! I'd definately get some gears, my 3.0 with 33's and 3.73 gears can barely get out of its own way. Plus any wheelin with those meats are gonna break stuff!
If it's a 95, it'll be the D35, as long as case is ribbed, its real and not the "hybrid-35".
So you have to remove the tires & center caps to lock the hubs? I see....:icon_confused:
So you have to remove the tires & center caps to lock the hubs? :icon_rofl:
Nice.. B4 I start locking the Hubs in 4x4 I Will be Swaping to 4.10 Gears..
What is Hybrid mean??
If your front diffrential is smooth with no ribs, it's a D35 housing with D28 guts = Hybrid. Don't waste the $$$ swapping in 4.10's, do 5.13's trust us. We've done it before, learn from our mistakes, lol.
Thanx for the Tip.. I have a Set 4.10s from my old Ranger that I never
put in.. If I could get 2 sets of 5.13s for $200 Total I would..
The 4.10s are already "Set Up".. Just have to Put/Bolted in...
Thanx,
Rob
Lil Ranger
Facts, I have seen
Doing any wheeling at all with 38s and IFS do not mix especially if any sort of locker is involved (too many moving parts to break). My 2.9 turns 38s sufficently with 5.13s, still does 75 down the highway and is plenty slow in low. 38s are perfect tires for the weight of a mid sized pickup. As for the lift, only add as much as needed (seen alot of tall roll wher lower rigs don't) and body lifts look like crap go with suspension, or cut the fender wells.
just trying to get a handle on how much lift you have exactly..
skyjacker 6" system, so 4" lift leaves, stock block,
6" front coils, and a 1.5" spacer under the coils?
how bad are you rubbing on the front fenders when you turn?...... O and it looks sick.....thats the way it should be done.... stuff the bigest tires o you ca on the smallest amount of lift....
