- Oct 21, 2007
- Age
- 36
That's a sweet idea. Grease fittings on a rotor hmmm... Gives me an idea..
Thanks. We will see how it works. I have read that too much grease can cause wheel bearings to over heat. However the only other believeable source I found this info on was from mercedes benz. IDK if its more of a concern at higher speeds or if it will be a problem at the normal speeds that this truck will see.
Well, to get to the grease fitting I need to
One more line to run tomorrow and then I guess I can start on something else.
i think you shoud start on making that beast RUN again! .. the hole Flintstones age thing was cool, but tryin to push some 35s... just isn't gonna happen.
