i have 6 8in fog lights 150 watt each waiting to be wired in will my truck have enough power to run all the lights and my head light all at the same time
6 will require 75 amps to run on a 12 volt system.
if you only figure on using batter voltage and not take the 2-3 volts for charging the battery back up it takes 12.5 amps to run just one light.
150watts/12v = amps
so if you plan running on those and any other electrical system you may want a 150-200 amp alternator.
you should also wire them on three switches so you don't pop fuses all the time.
Your right but we were just talking lights.scrambler... that's just to run the lights... what about the ignition, the radio.... how about the amps needed to charge the batter? 3 is small to run all that.
besides, if he ended up putting the lights in series by mistake the lights won't be very bright.
he should just get the larger alternator and call it a day... I mean, who doesn't want an alternator that can have a welder hooked up to it and weld stuff while the truck is idling?!!!
watts law
