6 150 watt fog lights
rangerdanger9398
alden ny
i have 6 8in fog lights 150 watt each waiting to be wired in will my truck have enough power to run all the lights and my head light all at the same time
if you google watts law, or figure the resistance of the bulbs and use ohms law, you can figure about how much current the lights will draw.
are you going to wire them in series or parallel?
Lets start with the basics.
6 lights x 150 watts each = 900 Watts
900 W / 12 volts = 75 amps
75 amps is more than a stock alternator puts out.
Options:
1) Put the lights on for looks only.
2) Hook them up and only run them one set at a time.
3) Hook up only one set.
4) Don't put them on (NOT AN OPTION)
Put them on, hook them up properly (1 relay per pair, Fused 10-ga power/ground wires, ground wires run back to the battery) and see how the existing electrical system takes it.
If the battery and/or the alternator gives you trouble replace them with larger units.
If it was me I would start off by replacing the alternator with a 120 amp unit and the battery with a Deep Cycle Optima Unit; increase the main wires from the alternator to the battery and redo all of the grounds more directly to the battery.
When putting this much wattage on the existing electrical system you will have a melt down, question is when and where and how many other components and wire will the melt-down take with it.
It is best to "Do It Right The First Time" and not worry about it.
Luck, great project...
6 will require 75 amps to run on a 12 volt system.
if you only figure on using batter voltage and not take the 2-3 volts for charging the battery back up it takes 12.5 amps to run just one light.
150watts/12v = amps
so if you plan on running those and any other electrical system you may want a 150-200 amp alternator.
you should also wire them on three switches so you don't pop fuses all the time.
150watts/12v = amps
so if you plan running on those and any other electrical system you may want a 150-200 amp alternator.
Averages, averages... the idea is to indicate the need for additional amperage in the system, a new alternator and battery.
12.5 Volts will results in a lower amperage draw, higher the voltage, lower the amperage draw per given wattage rating.
900 watts at 12.5 volts = 72 amps
The extra 3 amps will cover the battery re-charge, ha, ha.
Using 12 volts instead of the 12.5 or 13 volts will result in a heavy gauged circuit and in turn will handle the required load without worrying about over heating the wiring.
I use 12 on all of my circuits and have not had a problem.
later,
not to spoil your fun but i believe in ny you are only can have up to 100watts lights for on road use
while driving... I think he's planning on only using them while off road.
@scrambler... that's just to run the lights... what about the ignition, the radio.... how about the amps needed to charge the batter? 3 is small to run all that.
besides, if he ended up putting the lights in series by mistake the lights won't be very bright.
he should just get the larger alternator and call it a day... I mean, who doesn't want an alternator that can have a welder hooked up to it and weld stuff while the truck is idling?!!!
There is an aftermarket company named Power Master. They offer a new 200 amp alternator in a cast finish for $380.99 no core required. Carries a 1yr warranty. Advance can get them in 1 day. The 200 amp should be plenty!
Your right but we were just talking lights.
As IRK said you will need more than the 75 amps to make sure the vehicle can even run while the lights are on.
Yes a 160 or bigger Alternator will cover you but the cost... Ka ching...
Hopefully the lights will be setup in sets of two lights per relay and power feed. So series connections will not come in to the picture; I hope, I hope.
Ya but what price glory... I agree BUT can he afford the new alternator and if the draw is that much can he afford a new battery too.
What is being said here rangerdanger9398 is, "Do you really need all of the lights or do you just want them" ?
If you just want them, you will need to decide how much you are willing to pay for the setup. Lights-8, relays-4/wiring-enough heavy gauge 12 or heavier/fuses and holders-4/switches-4, new alternator-1 and new battery-high amp hour-1. ka-ching, ka-ching $$$$$
later,
Go to Summitracing.com, same 200 amp Powermaster alternator for around 315. If you print it off you can take it to Advance Auto and they will match the price (this way you don't pay shipping).
-plumcrazy
why don't you try white HID's i beleive they draw less than a filament lamp and as we all know by those import f*ckers they are bright as all hell.
Hey rangerdanger9398,
What are your thoughts on the subject ?
What are you going to be doing with all of the light from eight 150 watt Long Ranger lights ?:headbang:
Have you thought about a couple of lower wattage flood lights for filling effect in place of two of the higher wattage lights ?:beer: :icon_confused:
Have you tried mounting two or four lights and see how they work out first ?:icon_welder:
Always use RELAY(S) and grounding back to the battery for higher amperage draw components ! This reduces resistance in the circuit and almost eliminates grounding problems.:icon_bounceblue:
later,
