- Feb 8, 2009
- Omaha, Nebraska
yea there more going on there then i fisrt thought.
as far as getting to the front speaker i would say it just taking out the two front screws.
but as far as the back idk if it was good or bad just really different.
but my three speaker idea sound good still with 4 hours of sleep. it will work and be different. and kinda makes life easer. if you build a wedge box lest say 3 feet long you can have the sub in the middle chamber and the 6x9 right nex to it in there own chambers not that they really need it but it will look clean, and kinda cool in my two cents and its alot less fabing. and it you dont have the room to lay them out flat you can put the speakers on the side then you only have to cover the depth of the speaker.
so are you saying to mount the speakers shooting audio up? or straight into my seats? i'd assume the sub is going into my seats because it won't fit shooting up unless i get like a 5" sub lol.
i can't wait for this... anybody got a few different pictures of different wedge boxes?
if I can't afford the sub now, can I still make the same box, just not cut out the 10" circle for the sub? and just put the 6x9's in it? will look stupid at the time, but easier than making a new box.. unless the big box will mess up the speakers or anything without a sub in it.
and should i go ahead and buy the sub and amp at the same time? or get my amp with two fronts? or with the two rears?
i'll probably do 3 or 4 installments of money...
1) fronts
2) rears
3) sub/amp
well I wish I would have seen this earlier I have my door panels off of my 87. but yes that is just a vent it is so when you shut the door you dont blow out the seals around the windows, ya you can stop laughing I don't think my 87 was ever that tight but maybe when it was brand new. and I know that there is no spot in my doors for speakers yet, (not saying yours doesn't) but since I changed my dash to a genV dash I need to find a way to mount door speakers. My plan is to enclose the the sheet metal in the with a removable sheet incase I ever have to change a window. I will then take a speaker ring that will fit my speaker like thisBut keep in mind that I am planing on making new door panels and blocking of the vent area. and that I have alot to finish on the truck before I get to the door speaker. good luck. It looks like you can place stock 4" speakers in the dash mod your doors for a poss. 6"x9" and do a wedge bass box and amp behind the seat. should be a hell of a system.![]()
thanks, at least i think you are complimenting my truck.. lol
i'm only the second owner, the first being my grandfather
and he really took care of it nicely. only 83k miles on it too.
