Not Another CTOR Build
I know about regular cabs on b2 frames... and extended cabs on fsb frames, but I've never seen an extended cab on a b2 frame :icon_confused: so I'm looking forward to how it comes out :icon_thumby:
*edit, the more I think about it, extended cab isn't that much longer than standard... I've been tired lately lol
Buddies old stranger.
Another build going on on another board.
by chance does anybody know what their wheelbase is or if the rear axle has been stretched at all on either of those two builds?
everything to get the rear disc brakes put together...
going to assmeble the third once the paint dries......
Both have stock B2 wheel base. No way around it your going to have to put the mini tub in to clear the rear tires. The Silver/green/oxide/rust one was on 35's and the blue one will have 33's or 34's not sure.
i have my rear axle stretched 6"s back......i'll go farther if i have to
I would move the axle back till it cleared the cab nicely, run some coil overs and remove any leftover rearward frame portion.
yeah coilovers not in the budget..........getting some 63" chevys in a day or two
the third is, the axle housing will be black
little spacers to center the rotors to the studs to elimante any play in the rotor at axleshaft mating
Purple and done :teehee:
painting the center section before installing the third leaving the outsides primer till the spring perches, shock mounts, and brake calipers are welded on
I assume you used weldable primer so you don't have to grind the primer down again?
nope, i'll grind down the primer when it comes time, not a big deal
