if you cant do it by hand i dont wanna do it
peacefull under there
+1.
Pete
liquid wrench and some heat have always worked well for myself. then again i live out west and rust isnt to much of an issue here![]()
Remember though, it is thought that using lubricants on bolts to be torqued to spec causes inaccurate readings.
I don't know about ARP, but what you're saying - works. There is some theoretical argument over wet/dry torque, but most of us aren't building space shuttles.It's actually the other way around. Torquing dry can leave you up to 20% low, no matter what your torque wrench says. ARP reccomends moly or 10/30 wt oil. Dave
7-2nd has the right idea - for the right reason.Sevensecondsuv said:...load it up with antiseize before reassembly. Hit the threads on bolts, all bushing surfaces, ball joint bores, flat mating surfaces, everything. It will make taking it apart again 4 years down the road that much easier.
Here's another myth about Trucks! and Extreme 4X4, you don't need to go buy the most powerful, expensive welder to do the job. I proudly own a Handler 140 with Stargon gas hook-up.
When doing sheetmetal, exhaust, or anything under 1/8" thick material, this is the cat's meow. Anything OVER that, use the flux-cored wire, trust me, this can handle anything up to 5/16" material with proper joint preparation. I built a hitch receiver for my truck and this can pull a D-11 bulldozer if it wanted to.
The properties of flux core allow it to easily penetrate steel and give a very strong bead, just make sure you switch the polarity around when you change wires, and that you know the proper technique for welding flux core. It does take a certain finess to make it look good.
You can also stack the weld beads on top of each other when doing thicker steel projects. The more the better.
Is it gasless flux core? I always thought that stuff was sketchy
