- Aug 6, 2007
- Age
- 49
- Berrien Springs, MI
- State - Country
- MI - USA
- My credo
- If you can't go through it or around it, then go over it.
holy old thread batman.
Just because he lives in Minnesota doesn't mean he is giving bad advice. Pull your head out of your ass.
Again jackass, as long as it is installed properly an electric fan will be fine.Well Maurice, check out this thread from R-F, specifically post #7. This guy is
"PRO MOD", and admits to cooling problems, and AC problems with an e-fan, and UDP in Michigan!!!
Where has your head been????? You didn't understand MAKG's point at all!!!
http://www.ranger-forums.com/forum2/showthread.php?t=75566
You're in Minnesota. (YIPEE!)
Will you guarantee the work for someone living in central Nevada in summer? If not, you're giving bad advice. You're generalizing your situation outside its validity.
You're hearing the clutch on startup? Dang, you replaced a broken clutch, and claimed the working one was better. A stock replacement would have been better as well.
Thing is, competent engineers also understand test controls. Some technicians do, many do not. You're the latter.
Bird, you totally missed the point about diesels! I was trying to make a point about cooling capacity, and diesel vehicles require much more cooling capacity than ANY e-fan can deliver!!!!
If anybody can understand this, I thought you would!!
