- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
Hmmm... somehow I missed this one 6 months ago.
Definitely looks like mass confusion over torque numbers. A pinion nut torqued to 50 inch-lbs will lead to a broken rear end REAL quick.
(wondering how long it lasted
As for reusing crush sleeves, I don't see the issue if everything is put back together EXACTLY how it was, with the EXISTING parts (not new parts- nut, yoke & seal excepted), and maintaining the same amount of preload that was there initially. In this case the sleeve would still be maintaining pressure on the bearing race preventing it from spinning.
In ANY case where any bearings are replaced however, the sleeve must also then be replaced.
I've only worked on a small number of diffs (mostly my own), but I've never run into this issue with races not being seated.
What I did was make an installer tool using a long threaded rod and some large thick washers sized to fit against the races, and seated the races in the housing by tightening a nut on the end (not a whole lot different than the machined dummy pinion thing you mentioned). During final assembly I also gave the pinion a few smacks with a hammer from the front and behind just as an added measure that they were seated. After 4 years, the pinion still has enough preload on it that I can feel it when rocking it back and forth within the gear backlash.
)As for reusing crush sleeves, I don't see the issue if everything is put back together EXACTLY how it was, with the EXISTING parts (not new parts- nut, yoke & seal excepted), and maintaining the same amount of preload that was there initially. In this case the sleeve would still be maintaining pressure on the bearing race preventing it from spinning.
