Lets see your bumpers
finished adding a winch to the front of the bumper.
july long project
this was my first shot at a bender and welder both lent to me by a freind it was this thread that ispired the pro jectthe pipe i had laying around .it cost me 5 bucks for a bargen bin can of black spray bomb
finally finished
befor
after
bolts on and off in side 10 mins.
Heres mine in SolidWorks, will put up pictures when i build it someday... :)
this is very nice. If you don't mind, I would like to use this as inspiration to build mine. Could I possibly bother you for a ballpark on the material costs?
thanks a lot.
Just saw this, sorry for the late reply....guessing on material costs as I had the material already, I'd say $200 tops? Don't worry about using 'my' design, as I used several others influence in building it....
-andrew
Hahnsb2, I am in lust for your front bumper! :wub: How much do you want to build another? :pray: I'm not that talented. MJ
Thanks. I'll build one for the cost of materials and $15/hour labor, here's a couple other bumpers I've helped build for friends, not RBVs but maybe it can still give you guys ideas.
Bottom tube was removed on the Heep bumper and winch plate welded in place as well as the KC lights were mounted on the top tube like mine, just don't have a pic.
In this pics you can also see on my bumper where I added steel to the side of the winch plate to the vertical supports to fill the gaps.
Meh I'm not out to make a fortune (at least while doing work on the side), but if I ever obtain the skills (I really only have basic fab skills and tools) and means necessary to open a 4x4 shop I'd surely have to charge more than that. I'm probably going to start working with the waterjet at work which would greatly speed up cutting the steel plate and brackets as well as making them accurate, cutting everything with a 4 1/2" grinder takes forever.
