TRS Event 2026 Fall Colors Campout
Which of the following weekends works best for you?
  • Oct. 1-4
    Votes: 1 16.7%
  • Oct. 8-11
    Votes: 3 50.0%
  • Oct. 15-18
    Votes: 2 33.3%
  • Total voters
    6
  • Poll closed .
Featured Build Threads
Not at all. Very poorly named. I worked with a guy who shattered one side of the front bumper cover on his in a 2in pothole in the parking lot at work.
Don't be giving away the surprise...
Dang it. I went to pull my gmrs radio gear so I could put it in moms car for the trip. My antenna cable from the Superduty got crushed under a seat mount. I could splice it. But my understanding is that changes the inductance of the cable and it won't work right. So I guess I'll just be using my handheld radios. The antenna cable in the Ranger is neatly routed through the roof structure and b-pillar. I'm not pulling that out for a temporary use.
Sounds like a challenge.
You need to have a strongly worded conversation with your installer.
I have a magnetic antenna you can borrow if you want to swing by and grab it quick.
I'D like to blame the previous owner, who didn't put all the bolts in when he replaced the seats. But I've had the truck long enough that that should be fixed. Cable got under one of the mounting tabs for the seat that is missing its bolt and got pinched. 10cent zip tie would have prevented it.
You need to find a better deal on zip ties. 😬
I have cheap zip ties. I use cheap zip ties. I hate really cheap zip ties because they don't hold. I would rather use better zip-ties and fewer of them.
I just chose 10 cents as a ballpark guess. But even a 20 cent zip tie would have saved a lot if money in this case.
Time-wise, I'll be available to scope it out on Thursday, since I'm arriving Wednesday. But I won't have a suitable vehicle. For econonocal reasons, I will be traveling in a 2wd (fwd?) Ford Flex. Not great clearance, not great tire tread, not my vehicle to put a lot of pinstripes on.
Makes two of us. I won't have the coilovers done in time. Figure me in either an Edge or GMC. Maybe the jeep if I can handle the carbon monoxide that far...
Seeing you stagger from your Jeep half unconscious would give a whole new meaning to 'death wobble'.
It happens. At least I'll be in a Ford. And, honestly, I'm happy just to be showing up.
That's already much better than me. I'm glad you can go. I can't say much, honestly. I hosted a Ford Festiva gathering in a Saturn SL1. I'm looking forward to the pics after the event!
Upcoming TRS Events
Featured Ranger Based Vehicle
