TRS Event 2026 Fall Colors Campout
Which of the following weekends works best for you?
  • Oct. 1-4
    Votes: 1 16.7%
  • Oct. 8-11
    Votes: 3 50.0%
  • Oct. 15-18
    Votes: 2 33.3%
  • Total voters
    6
  • Poll closed .
Featured Build Threads
Sure. Trade the goat for a 6.5 turbo, 4 spd, 4 door, soft top Humvee and we can make that deal happen.
Depending on the goat that would be pretty easy...
Anyone that's coming to the campout have an extra radius arm you don't want or need? I've been wanting one to examine the size differences between the stock arm, Rancho arm, and Skyjacker radius arms.
Which ones? 28 or 35?
Aren't they supposed to work either way?
Yeah, basically only the shock mount is different.
I reused the D28 arms with my D35. Partially because I like the shock mount better and partially because the D35 arms were torched in half when they pulled my axle out of the donor.
Doesn't matter.
I have a 1994 d35 laying here. Dm me with what you need out of it. You can have the arms, the one has a hole in it.
PARTIALLY because they were torched in half?!?? I would think that would be most of the problem with using them.
2wd and 4wd the same? If his falls through I might be able to put my hands on a spare first Gen 2wd arm.
I was actually going to put out feelers for 95-97 2wd beams and knuckles. No other parts needed/wanted, just beams and the bare knuckles.
I was wanting to reuse my D28 arms for the shock mounts before I even had an axle... so that is why I gave that higher priority.
Upcoming TRS Events
Featured Ranger Based Vehicle
