RPMs dropping and stalling at stoplights
keel
Forum Member
Seattle
N/A
Other
Foxbody Mustang
Vehicle
Drive
2.9L
1990 Ranger XLT with the 2.9L and auto trans. No CEL, no modifications.
Runs pretty much perfect except that when slowing down to a stop or idling, the RPMs will occasionally drop really low and the engine will either almost stall or stall out completely. Only happens at operating temp. If the engine is able to recover, I notice that all the cluster lights dim and the oil pressure gauge will go to zero like the truck has lost electrical power for a couple seconds. I assume this is just because the alternator isn't turning fast enough to maintain voltage when the RPMs drop but it could be related to something else.
If the truck stalls, I can easily just restart it and drive away like nothing happened.
So far I have tried cleaning the idle air control with some MAF cleaner and I was able to get a decent amount of crud removed from it but it didn't fix my problem.
The tachometer is also wildly inaccurate although I have no clue if this has anything to do with the stalling issue or not. It will bounce between reading normal and reading super high with no rhyme or reason and seems to have zero effect on how the truck performs.
Did you Pull codes from ECM?
No, can I expect to see codes even if there's no CEL?
Possibly, yes.
Tach and stalling are likely related tbh.
Okay I will try pulling codes then. Any theories as to why the tach would be acting like that and how to fix?
Hall effect sensor, but I'm usually wrong.
Let's see what the codes say
That model I'd suspect the TFI too. It's between that pickup and the coil right? I know it's hard to get a good one new these days.
Could be a few things. IIRC tach is the hall effect in the distributor. Mine used to flutter until I changed the sensor. Leveled out stalling issues as well.
But, not sure of OPs issue. Could be a ton of different stuff, and I'm completely unfamiliar with auto's.
Okay I pulled codes.
KOEO - 11, system checks ok, nothing stored in the memory
Ran KOER and forgot to press brake pedal/blip throttle - got 41 system lean, 77 no goose test, 74 BOO circuit
Ran KOER again properly - got 13 idle speed control (but no 41 strangely)
Looks like I might need an O2 sensor and an IAC. What do you guys think?
IAC is hit and miss, some are junk out of the box. For stuff like that, I abuse Amazon and order 3 or 4 different ones, use the best, return the rest. YMMV.
O2 lasts 60-80k mi before they get lazy and crappy.
O2 shouldn't cause stalling issues. IAC will.
Tach issue has me scratching my head tho.
I'm trying to channel my inner RonD...
Yeah I would really like to resolve that too but the truck was doing that long before it was having idle issues. It's very strange, sometimes I will be cruising on the highway and the tach will suddenly jump up like 2k RPM and it will look like I'm doing 4k+ RPMs down the freeway even though I'm just chilling in overdrive. Then it will jump back down after some time. Or it will just consistently read 500-1000 too high and then the next time I drive it is normal.
I have a 2006 Dodge ram with a flaky tach. I bought it from the previous owner like that. He said he had the dealer look at it and they couldn't figure it out. Mine usually shows 0 until I floor it with a load. Then it runs up to 5000rpm. Once I let off the gas back to 0rpm. I've put 100,000 km on the truck with the tach like that.
MAF issue, maybe? The tach is likely just responding to the actual RPM drop. Sounds like a dirty intake.
Pretty sure the truck uses speed density, no MAF. I tried looking for one and couldn't find it.
Anyway I replaced the IAC and the O2 sensor last night, will report back with results. O2 sensor was a giant PITA to get to so hopefully that code won't pop up again.
Cali emissions is MAF. Rare, but they do exist.
Yours should be speed density.
The stock MAP sensors are kinda ass, but they do work.
