What are the members using on their chassis parts these days? Looking for something single product to paint washed wire brushed/bead blasted chassis parts. Used POR15, Rustoleum Prime and Paint in the past.
Rustoleum is good for lawn chairs. It's not really an automotive paint which is made to lst longer and deal with "salted" roads.I used POR15 but I only wire brushed the frame and crossmembers, I'm not sure how well it would stick to freshly blasted metal.
I used Rustoleum on my 69 Bronco in 1976 and I'm still pissed about how badly it peeled.
Sherwin Williams makes commercial barge paint…This is relevant to my interests.
Is any of the stuff Eastwood sells OK? It seems like so much chemical stuff was reformulated in the early 2000s due to some EPA stuff. Hard to know what to trust anymore. Maybe something marine grade that's not marketed to the general public?
And the paint we use at work on Kubota tractor parts. BTW, it's called Kubota red. It looks orange to me. We have paint samples on the pegboard from the opening of the plant in 91 that are actually red. The color just keeps getting lighter.Sherwin Williams makes commercial barge paint…
You can also seal it with acrylic urethane varnish or clear coat. It lasts a long time and is compatable with nearly every paint.There shouldn't be any reason that you can't put the best oil based paint/coating on the frame/body and then run a protective film over that like cosmoline, oil or wax. That way you'd get extra protection.
You will probably get what you pay for. It probably will not last through the winter, unless maybe you live in ArizonaFrom the video the Rust oleum base top coat seems to be the most economic.
Only holds up if you apply 3-4 rather heavy coats. It’s my preference, but, I live in sw TN. Real winter, in a rough year, might last 2 weeks.From the video the Rust oleum base top coat seems to be the most economic.
