Restoration Chassis Paint suggestions
greymarketassets
Forum Member
Pawling
NY - USA
What are the members using on their chassis parts these days? Looking for something single product to paint washed wire brushed/bead blasted chassis parts. Used POR15, Rustoleum Prime and Paint in the past.
Depends on the part. Frames I brush paint with oilbased enamels. Cheap 1-2” chip brush and a good heavy coat, repeated several days later. Really old projects get a rust busting red oxide primer first. And then a color coat or three.
Springs either oilbased enamel or aerosol chassis and rollbar paint. Same for the rear axle.
Twin beams get a black epoxy paint. Rattlecan appliance epoxy or similar.
I used POR15 but I only wire brushed the frame and crossmembers, I'm not sure how well it would stick to freshly blasted metal.
I used Rustoleum on my 69 Bronco in 1976 and I'm still pissed about how badly it peeled.
I would follow this guys series a bit to decide on which is best for you, and POR15 is not something you want to use. YouTube is littered with videos of people showing failed POR15 frames.
Rustoleum is good for lawn chairs. It's not really an automotive paint which is made to lst longer and deal with "salted" roads.
The very best product, I believe, is Synmast. It is a solvent free epoxy which can be painted on either bare or painted metal. Solvent free means it will not soften a paint that had been previously applied. It's not cheap. The minimum is a one gallon can for around three hundred bucks. That guy is right about POR15. It's not a paint anyway. It's a primer. It may hold up down south on dry roads, but otherwise needs a top coat and maybe also an acrylic urethane sealer over that.
This is relevant to my interests.
Is any of the stuff Eastwood sells OK? It seems like so much chemical stuff was reformulated in the early 2000s due to some EPA stuff. Hard to know what to trust anymore. Maybe something marine grade that's not marketed to the general public?
Sherwin Williams makes commercial barge paint…
And the paint we use at work on Kubota tractor parts. BTW, it's called Kubota red. It looks orange to me. We have paint samples on the pegboard from the opening of the plant in 91 that are actually red. The color just keeps getting lighter.
There shouldn't be any reason that you can't put the best oil based paint/coating on the frame/body and then run a protective film over that like cosmoline, oil or wax. That way you'd get extra protection.
You can also seal it with acrylic urethane varnish or clear coat. It lasts a long time and is compatable with nearly every paint.
From the video the Rust oleum base top coat seems to be the most economic.
Only holds up if you apply 3-4 rather heavy coats. It’s my preference, but, I live in sw TN. Real winter, in a rough year, might last 2 weeks.
If I moved back to WA, OR, ID, MT? Real mountains, real ice, sub-zero mountain pass temps for weeks at a time? Epoxy primer, catalyzed urethane color, catalyzed urethane clear, and… Pump sprayer full of hydraulic oil. Saturate any/all seams, bushings, pivot points, etc. ALL 11 trucks on the farm leak, engines, transmissions, differentials. Unless I decide to paint the chassis, they stay gooey.
