Aces Killshot Fusion EFI Swap
So is that saying it added fuel at low throttle and subtracted at higher throttle positions?
Yeah, positive numbers are it adding, negative is it taking away.
Ideally you want it +/- 5% so the adding isn't too bad.
Well I have had enough confidence in it to fill the tank twice.
Averaged 12.4mpg on the first tank... but if had the little eco thing that grew leaves the nicer you drove like a newer car or ev... that branch would have been on fire.
That is a little bit of tuning, a fair bit of test revving, some towing a camper, a lot of mixed highway/city driving and a lot of letting it sing. :3gears:
I imagine it's hard to stay off the skinny pedal right now.
Still running great but I do have a few notes for anyone else if they go down this road.
It was hot starting hard. By hard I don't mean cranks forever and doesn't want to start, I mean like fighting with the starter. Then it was almost like slam to running like an electric motor just flipped on to operating speed.
I played with crank timing and it only got worse.
Thinking it was getting too much fuel prime I dialed that back... and again it got worse.
Bumping up the fuel prime up made it better, not great but better.
Then it got warmer outside (ambient was half of operating temp lol) it started doing it cold as well.
Then a thing came across FB about a guy having a similar issue, a responder said he had a similar issue and dialed back the "Park Air vs ECT" at the coolant temps it was having issues. So I bumped them all down a hair above 80*... and shucky darn it starts pretty good now.
I need to try to dial back my fuel prime and readjust but for now it starts really well.
I am guessing it was trying to give it too much air so me throwing more fuel at it was halfway making it better.
I snagged a windshield phone mount to watch things on my phone as I drive, kinda cool the IAT is only 10* above ambient per my JY Tahoe mirror. That was about a 80* running 65mph with a slide in camper in the back, wasn't taxing the engine but I am sure were making more heat than normal. Kinda neat for my DIY cold air intake. 😎
And they just dropped Gen2 tuning software...
It is supposed to be easier to figure out... so now I can start all over again lol.
I downloaded and glanced at it earlier. Everything looks to be in the same place but it felt a little more cluttered. Especially when you go look for a table.
When I was using the previous version, I had the settings and tables I used the most "bookmarked" under the Custom tab.
After my last tweak I did with my phone I need to save my tune before I get brave enough to change software lol.
Right now the Skamper in it isn't really the time to be playing with the tune so it is going to be waiting for a bit.
I did get the return fuel line built from between the TB and FPR tonight. I don't have enough fuel line to get from between the TB and fuel filter. It was a short night Really muggy, june bugs were THICK and then a thunderstorm chased me inside.
I submitted a thing for Aces "Tech Tuesday" thing on their youtube and they actually replied!
I didn't get the answer I wanted but I did get a clear answer about what it does/doesn't do. @4:36
So basically nothing changes for the Efans aside from the ECM doing the grounding rather than the temp switch.
To circle back to this...
I charged the air up friday night to see how this new fangled contraption will work.
Engine catches itself when the compressor locks up and fans come on and snaps the idle back to where it should be cleanly. Perfect, I can't ask for better.
Both fans kick on as the compressor runs and kick off when the compressor kicks off as long as the engine isn't asking for fan (and already running) so my relay block is working how it should.
Really made a huge difference. With the Edelbrock 4bbl it would pull the idle down. I think it would have been ok with a slushbox but it goofed up my shifting, it would pull the idle down lower than I was expecting when I would go to shift... sometimes. If the compressor was cycled off it would be normal. So I never really knew what I was going to get when I pushed the clutch in. I usually just ended up turning the A/C on once I got up to speed and set the cruise. The other day I was running it around town and all was right with the world, it was awesome.
Much better than this BS would have been with the carb.
Neither here nor there for the EFI converter but the A/C is cooling awesome as well. :icon_thumby:
this and the 5.o swap thread eric has...is a thing....that consumes my lunch to keep up....have to find page i left off at.
Sounds like you are still liking the Killshot. I've been getting the Facebook ads for their sales. I've got the Holley Sniper on the FE in the F-100, but I'm tempted to grab one of the Killshot Lites or Duces units for the 2.8L on the wrecked truck.
Want to put it back into something, need to get it out of the r ck and dispose of the rest. Might find a home in the drift truck project temporarily, and I rather not mess with rebuilding the carb. The Duces would probably be perfect for a little V6, but that 2.8L has the Offy 4bbl and Holley 390 CFM. The Killshot Lite says good for up to 400 NA horsepower, which should work for the little V6 or if I throw together a 5.0L for that truck.
Only a maybe at this stage. Biggest issues is I'm not a tuner and that truck won't be street driven enough to do much self learning. Also figuring out how to make the system play nice with a duraspark distributor.
If you get to reading I think the 4bbl kits recommend at least 200hp, I was kind of nervous with mine because that is about where mine is at but so far it is working good.
Its like $400+/- but there are guys that can tune it for you remotely also. It will need tuned, it isn't a plug and play thing at all. Tuning at least with the old software wasn't super intuitive either. I have had fun researching various issues and figuring things out but it isn't for everybody.
The normal 4bbl kit says 200-650 HP in the manual IIRC and comes with the 100 lb/hr injectors. The Lite version is listed as up to 400 HP and has smaller 65 lb/hr injectors. From the manuals:
Killshot Fusion:
Killshot Lite:
Editing my previous post to clarify that I was talking about the Lite version.
The Sniper isn't really a self learn system either. With the condition of the FE in the F-100 it hasn;t been worth paying to have to tuned yet. Depending on what I end up with for the rebuild in it, the Sniper might not stock around anyway. Might need more than it can handle, or it might get a newer engine swap.
i would likely keep the offy and 390. unless boost was on the menu.
