4.0L SOHC 4.0l SOHC tuning clippings and notes
Featured Build Threads
I'm watching, just don't have anything constructive to add.
I understand why at this point damn things can't tune themselves. Have basic parameters set to get it started (engine size, number of cylinders, sensors connected, ignition type, etc.) then once the O2 sensors warm up, let the computer learn everything from that. It should be able to build it's own damn tables. LOL
There are some people that have tried tuning with chatgpt/chatbots... results are dubious to say the least.
Some modern vehicles have "neural networks" now as well. I don't know enough about them to speak about them, though.
Quick note on AFR:
SOHC has global AFR set to 14.68... ideal when gas was gas, but not now. Most fuel in PA is E10, some are now E15... E10 stoich is 14.07... so possible that the computer is always going for a slightly improper AFR as a result.
Here's an ancient forum about it:
May run a few data logs after wideband install to see if there's a difference when setting globals at 14.68 vs 14.07. Not sure if there will be one other than mildly increased or decreased fuel economy. Unknown if difference in knock sensors due to current inability to read the PID.
If I can just set my global fuel command to a lower AFR and the pcm will do it accurately, I have a very clear path for running 87 octane with 3.5 psi of boost pressure - just increase fuel globally in to overcome possible knock.
Tried changing my stoich global afr to 14.13 instead of the factory 14.68. Truck ran meh for 100 or so miles, then my trims started dipping into the -11+ territory.
Not certain why this one happened. It seems the pcm is programmed to bias towards the o2 sensors and trim around holding what they're reporting as stoich, which should be 14.7.
Need wideband.
I noticed last night while messing around, base fuel table is already offset to accommodate for e10.
Not commanding full Lambda, this offset actually puts you just under 14:1
So theoretically shouldn't need to change the stoic to compensate for the e10.
Incidentally, I did the same thing and changed the Stoic to 14.1 and LTFT went from -3% to -6%.
there must be some setting in the ECU that is conflicting with the commanded stoic value.
Something like, we changed what AFR we are using to set the base fuel tables, but not the desired AFR in closed loop?
I also wonder if it has something to do with the narrow band sensor not being able to properly read a 13.8 afr?
We may need to end up running fully in open loop on these if we need to modify the AFR significantly. Could just be a hardware limitation.
I have a book from LaSota coming dedicated to tuning Fords in HPTuners. I figured they were as good a source as any considering they worked with Moddbox to do tuning for their SuperCharger kits.
I am starting to think this is completely true. I keep hitting issues that have no other explanation.
Will go into more detail this evening... need to test a few things.
Briefly looking at a file for 4.0 mustang, there are a lot of parameters not available on the ranger version.
It looks like the mustang has a electronic throttle, electric fan, map, ect.
still spanish oak.
In the mustang file you have automatic shift points for WOT 4 Low vs normal WOT.
I think someone did a half a job when building the file for the ranger ECU.
Following this with nothing to add. I’ve never tuned an ecu before but definitely find this interesting even when I don’t understand half of it 😂 good thing I can google stuff I don’t understand.
Well. I think I found the power loss issue.
IAT spark table pulls a TON of spark when intake Temps go over 100f. Will update when I can get a screencap.
The more I look at this, the dumber it gets.
Even the factory 2.9 air box reached out to the front header to grab fresh air. This one sits directly in the fan wash and has air blockers all around it. There's a spark "wall" in the IAT spark map. I need to screenshot it when I can.
I can not for the lift of my find a way to track Knock response. I've tried everything I can find that looked related.
I have a feeling HP tuners is not setup to read the these stock sensors, and can only read voltage sensors not frequency type.
However, I've seen logs from guys with mustangs running the Spanish Oak tracking average knock response, it also looks like they are reporting in volts.
may need to run an PLX knock sensor to get any good data related to knock.
I think we're at the point where we need to talk to hp, or someone like Banish or LaSota
You are missing parts. There is supposed to be some extra blockers and plastic bits to pull in air from behind the headlight.
I’m guessing someone removed them to install a CAI and didn’t put them back.
I checked my IATs this morning and they stayed within 5* of ambient temp when driving.
You are missing parts. There is supposed to be some extra blockers and plastic bits to pull in air from behind the headlight. View attachment 147047
Well. Shit.
No chance there's part numbers on those shields?
Upcoming TRS Events
Featured Ranger Based Vehicle
