2.3L ('83-'97) Time for a new clutch 96 2.3
Yep, I have a Luk flywheel on me I got in case it was bad. Happy to put the $50 into the clutch job but for my own knowledge I'm curious if the flywheel looks usable.
I don't have a lot of experience, but if I was hard up for money I'd use a DA sander and rough up the surface for a new clutch. Even hand sanding if necessary.
I do that a lot on rotors for my beaters.
Does this photo tell me i have a leaking rear main seal? the clutch was completely dry.
well, the clutch is bone dry and the bell housing doesn't show signs of leakage, though there is a little grim built up (pic 2). maybe some seeping? I do have an oil leak somewhere as the oil pan shows a lot of signs.
i'm leaning toward not replacing the rear main seal.
  • Time for a new clutch 96 2.3
I'm inclined to leave it alone. I once replaced a seeping rear main seal because I already had the motor out. Dam if it didn't leak worse after...
I decided to replace it. Is Victor Reinz any good? Might not be able to get my hands on a Ford OEM today.
Good to know.
I've certainly installed worse. The 2.9 flywheel had a burned spot about the size of my thumb (not the nail whole thumb) that was so bad the metal was flaky. I put it in anyway cause I was broke. Proceeded to drive the truck 8 years with a 4.0 on that clutch. Probably the reason my FM146 survive as long as it did. That bad clutch acted like a fuse. It slipped before I broke something else...
ok rear main seal in hand. Never done one but it looks straightforward though I understand it requires great care to not have it leak in the future.
i rented the tool but the largest disc isn't big enough. I could find a plate and drill a hole. I assume it just needs even pressure?
it comes with a plastic sleeve I assume is part of the install process?
That sounds right to me.
old seal is out. I'm reading conflicting information about installing. I think I'm supposed to install it dry, it came with a plastic install sleeve.
  • Let the oil finish dripping
  • Clean the bore and crankshaft with brake cleaner.
  • Wipe everything completely dry.
  • Install the seal with the plastic sleeve still in place.
  • Press it in square.
  • Remove the installation sleeve if required by the seal design.
  • Do not rotate the crankshaft immediately afterward.
Does that sound right?
I once followed the instructions to install a front main seal dry to the crank surface. This was in a Haynes or similar book for a 4 cylinder in a neon. It was wrong. I cooked that seal on first startup. Regardless of what they tell you be sure about installing dry, be wary. Perhaps the outer edge to the block is dry but crank contact I feel needs lube.
