I'm still trying to figure this out
Hey,
When you’re trying to install a bearing that should almost just slide in, and you have to screw around with it for a few days, and ask help from a bunch of old farts who just bust your balls, you can have circular emotions.
Got a P0340 code this week. Went away today but I think I'm hearing a slight chirp. Guess the cam synchronizer is on its way out. Still the original at almost 226k. Guess that's pretty good.
the numbers on the rockauto and autozone bearings match at 5707 but the original bearing says 0?-59722. according to google, these two bearings have the same measurements
also it looks like i shaved some hairs off the axle-housing/bearing-race. how bad is this?
i have a 36mm socket ready for pounding and the new autozone bearing is in the freezer.
*edit*
THE BEARING IS IN
sanded down that hair-thin lip and got the bearing in with old bearing as perfect size press, block of wood + big hammer ....then finished tapping in by hammering the big wooden hammer handle in a circle
the numbers on the rockauto and autozone bearings match at 5707 but the original bearing says 0?-59722 or 0?-597SS
Did you post this somewhere else? I just replied to you somewhere.
Im not sure today's youth know how to tell time...
So funny about that...
I coach HS football. For kickoff (I dabble in special teams) I always used a clock. So 12 means deep middle. 1 is deep right, 2 is right, about the 10 yard line and so on....
About four years ago I had to change it. I made it digital. So 1 is deep left. 2 is deep middle. 3 is deep right and so on.
Not making this up.
Not making this up.
I believe ya...
I owned a pizzeria... probably employed a couple hundred high school kids over the 10 years I owned it. We would time baked products to expire 30 minutes after they came out of the oven. The boxes were printed with a 1 through 12 on the edge of the box. So if a pizza come out and the minute hand was pointed to the three... thirty minutes from then the minute hand would be pointed at the 9. So you mark the 9 and expire the product when the minute hand was past the 9.
Less then 25% of them could understand that simple process... even the smart ones.
I believe ya...
I agree, pitiful.
So where is this pizzeria, and when is the slow time when there might be some out of date pizzas?
Asking for a friend
*edit*
THE BEARING IS IN
I doubt that you actually scratched the race, and I doubt that you sanded the race out. It’s extremely hard steel. I suspect the mark was residue from whatever ran across it. Then again, the bearings are also extremely hard. But I suspect a mark (think of a magic marker) FROM the bearing, or something on it, not damage to the race.
Now let me talk out of the other side of my mouth. If you actually scratch or crack a race, it’s toast, it’s done, stick a fork in it. The bearing will fail very quickly. But if I already had it back together, I’d also take my chances, but I don’t have to rely on mine for transportation
It’s possible the hardness of the bearing scratched the axle housing. And, me too, I would also sand that down. Then, flush flush flush, with solvent (cheap) or brake cleaner (expensive) to get all the grit out.
And I’m proud that you took my advice on using a wooden dowel. The block of wood, of course, is just, really, a large dowel, one that isn’t round. And the circular motion! My work is done here…
I’m praying for you, Young Buck, I hope it works! Stuff you’re going through is how we all learned, years ago. Years and years ago, no videos, no websites, no take a picture and get an instant answer, prehistoric ages, and technology. You don’t realize the blessings that, in this great nation, the USA, you can go online and find anything you want.
(do you like how I slipped in “God bless the USA!)
Good luck!!
Good luck!!
Fortunately, he's not talking about scratches in the race. He's talking about scratches in the axle tube where the race should be located.
lest 'ye all get confused, that's a side load bearing.
variations of it are used in many removable hub bearing units and other things.
I agree, pitiful.
Asking for a friend
Sadly Rick...
Most expired product got pitched to the dumpster.
If I would have gave them away... I'd have a line of folks wanting free pizza instead of buying one and helping me pay the rent... payroll... the food bill or my electric bill.
I tried donating them to local shelters. The red tape involved in that was nuts and they rarely showed up to haul it away. I offered to deliver it but that didn't follow the process... so no go.
So... the local homeless were pulling it out of the dumpster... instead of the shelters.
They really didn't seem to mind.
Sad...
I have figured out that even lowered so it's a half rack, the bed rack still catches wind fairly badly. I need to get the wood for the top and either stain/seal it like a boat gets done or cover it/color it black or grey so the wood doesn't get damaged by rain and the sun.
Upcoming TRS Events
Featured Ranger Based Vehicle
