Baffling electrical issue please help
thatbotguy
Forum Member
Harleysville
PA - USA
Vehicle
Drive
2.9L
I just got done replacing the high pressure fuel pump on my 88 ranger and now it won't prime. I checked the fuel pump relay on the inside of the passenger fender and was able to make the pumps run by jumping it from the battery, and the relay bench tested good. A multimeter on the plug shows only 1.8 volts across the signal prongs of the plug with the key on, my assumption is that it should be 12. The other relays test at the expected 12 volts. Does anyone have anything idea what could be causing this? I'm stumped, I've checked everything I can think of to check without pulling apart the wiring harness. The computer under the passenger side dash looks fine as well.
Tia
Wait for it....
Does it have fuel in the tank?
Im also confused by your test procedure...
If your showing only 1.8 Volts you have a bad ground somewhere, check your ground line(s) thoroughly. The same thing happened on my boat. It read low voltage, turned out it was poorly grounded.
The EEC relay powers the fuel pump relay when the key is turned to run. The ECM grounds the primary coil on the relay for a couple seconds on key up to activate the relay and close the secondary side to power the pump... to prime the system.
Your high pressure pump relies on the low pressure pump to deliver fuel that far. High pressure pump is more of a pusher then a puller pump.
There should also be a fuel reservoir in that two pump system... between the two pumps.
I will take some pictures after work tomorrow, when I don't have to rely on a shitty flashlight.
I didn't explain it super well but everything south of the relay works as expected, as well as the relay itself. Somewhere between the key and the relay there is an issue
Once the ECM sees more then 6 or 700 rpms... the ECM ground the relay coil to run the pumps.
I unplugged the high pressure pump and was able to hear the low pressure pump run so they both work. The green relay is the one with the low voltage, is that the eec relay? I'll do some more scientific testing tomorrow
Green is fuel...
And if both pumps are running... it still won't prime the system and fire up?
I tried jumping the pumps to prime the system and it didn't work, though I think I had one of the spark plugs pulled at the time and I didn't really give it a good try.
Well... take a deep breath
Get your business in order... and let us know.
It should of started on 5 cylinders.
You sure its a pump issue and not injectors?
Regarding the perceived ground problem;
Since the PCM supplies ground to the fuel pump relay coil, if you measure across the coil contacts where the relay plugs in, it WILL look like there is no ground, unless you turn the key to the start position to make the PCM supply a ground. And, even then, it will only be for a few seconds.
The best you can do is measure from the coil contacts to ground and make sure the PCM power relay is sending voltage to the coil.
Upcoming TRS Events
Featured Ranger Based Vehicle
