- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
99 Crown Vic civilian
I got all these other issues sorted out except for one....
For some reason, under anything more then mildly moderate acceleration...it will drop charge. Battery light comes on, and the volt meter drops.
Any other time its totally normal.
It ALWAYS happens between 35-40mph in 1st. I have cleaned every ground, the alternator has tested good, and in order to get it to charge again i have to pull over, shut it off, and it immediatly fires back up...so i think cables are fine. Doesnt matter how many accessories i have on or anything.
But heres my question...could this be a cluster issue? I know on these the battery light is part of the charge circuit. Im also having an issue where the low fuel light blinks for the first 40mi or so randomly after i fill the tank...but does not come on when the tank is low. But seeing as how it always comes on at same speed, in same gear makes me think something goofy with the alternator...but it will not do it on a 45-70 freeway pull in second...which should hit the same RPM range.
Any ideas?
Any ideas?
