ECU relay failures
j-driver
Forum Member
⭐Supporting Member
Seattle, WA
N/A
Drive
I've got an '87 XLT (2wd) that I seem to be unable to get a working ECU relay for. The truck was running before the original relay failed. I ordered two on ebay, carquest surplus stuff, and both turned out to be bad. So this time I ordered the SMP RY-111 on Amazon, looks the same, and it seems to be nonworking as well. I tested one of the carquest relays before installing it, making sure I had the polarity right (positive on the center small terminal, #2) and it was bad right out of the box. I even went to the extent of hacking a GM relay to get power to the ECU, first without, then with a flyback diode, which worked at first but I think I had a cold solder joint in the hack that I did.
Two questions. First, the stock relay is said to be "electronic". I took the cap off one of the Carquest relays, and sure enough, there's a very small component board inside that controls the trigger coil. Based on my very limited knowledge of electronics, it looks like they use a small transistor to drive the relay coil, an RC circuit to give it a soft start, and a flyback diode to suprress the voltage spike when it shuts off. So does anyone know if all the bells and whistles on this relay are really necessary, or can I get by with wiring in a different relay with a flyback diode and not burn up the ECU? I'm getting tired of going through the same loop again and again.
Second, is it possible there's a problem somewhere that's causing the control boards to fail? If so, how would I troubleshoot it? I'm reasonably sure that at least one or two of the relays I bought were bad right out of the box.
I'm curious whether anyone else has had a similar experience. Seems trivial, but the truck won't run without some way of getting power to the ECU. Appreciate any help or feedback.
  • ECU relay failures
Way above my pay grade.
Where's @RonD when you need him...
I'll give this some thought in the morning. Which terminal is #2? Most times, automotive relay terminals are labeled 30, 87, 87a, 85, 86. 87a, in the center us rarely used because it is the "normally closed" contact.
Thanks, the GM relays are almost all like that and maybe the newer Fords are too, but I haven't worked on anything newer than what I've got. Those relays usually have a pinout stamped on the top so you know what's in them. This one has just 4 terminals, two large ones -- one from the battery via a fusible link, and the output to the ECU, and two small ones, one that takes 12v from the ignition switch, and one to ground.
It shouldn't matter whether you use a magnetic relay or electrinic one. They do the same job.
Do you have battery voltage at the relay? One of the contact terminals should have power all the time. One of the "coil" or control terminals should have power when the key is in run or start.
You should be able to use a jumper wire and temporarily jumper across the contact terminals to get power to the ecu. See if that gets you running.
Another thing to check is the ground connection for the relay coil. If the ground connection is loose or dirty, it won't work.
I can't imagine why you would have circuitry inside a relay beyond the coil. You wan the contacts to close and open as fast as possible. Less possibility of arcing the contacts.
(That's for DC. For AC a way to only switch at the zero is a good thing.)
I could see Ford realizing they needed a diode in circuit and finding it easier/cheaper to add it inside the relay.
The whole thing is just weird.
It's "instead of" the coil and contacts. A transistor and supporting components to turn the output on and off. Solid state relay. I, also don't see a need for that. But...
That actually makes more sense. In my experience a solid state relay is more reliable. Also totally unnecessary for the use of a PCM relay.
Many thanks to all for the responses and feedback. I did use a jumper to check for power at pins 37 and 57 of the ECU connector but I haven't wired in a substitute relay or powered up the ignition with the computer and TFI connected.
I decided to take the dive on this and see if I could figure it out by home schooling myself on the internet, but it didn't take long to see that I was in over my depth on the electronics stuff. I think I did get a couple of things figured out. Using a flyback diode eliminates the reverse voltage spike that happens when the power to the relay coil is cut, but at the cost of slowing the dropout time and increasing arcing at the relay contacts. The ECU might not see the reverse voltage spike since it would be traveling from the relay back in the direction of the ignition switch, but other components including the electronics in the distributor might be exposed to it. The ECU would see whatever waveform interference happened from the contacts arcing during shutdown. So apparently Ford designed this relay with a fairly complicated snubber setup inside the relay itself to address these and maybe some other issues. I still think it's probably over-engineered -- in particular I don't see the need for using a transistor to drive the relay coil -- but I don't know enough electronics to be sure of myself in tampering with it or bypassing it.
fwiw, after I messed around with a substitute relay the first time, the PIP sensor in the distributor failed and I think now that I might have caused it. Also, I tore one of the small cube type GM relays to pieces and the one I tore apart contained a resistor which I understand can also work for surge suppression but not as well as a diode. Advantage is that it's not polarized like a diode is. And cheaper.
So plan B, I guess, is to keep buying relays and hope the next one I get is a good one. It turns out Oreilly's sells one for about $20 that's generic but carries their lifetime warranty. I have one coming and I'm hoping for the best.
An update:
So I got the relay from Oreilly's -- 4th try so far -- and it too didn't work. But unlike the SMP relay it did have a schematic printed on the side which I took a picture of. I've never seen or heard of an automotive relay with complicated electronics like this.
I found some older threads on this site that seem to be looking at the same problem, in particular: https://www.therangerstation.com/forums/threads/eec-relay-electrical-issue.178872/. In that case codeJunkie seems to have solved it by wiring in a different relay without problems in the short term, at least.
The issue seems to be that the replacement relays that are usually given for this application (SMP RY-111, Rostra 600226, maybe others) are pinned differently from the originals and they won't work without rewiring the relay socket, specifically, switching the ignition and ground wires.
Apart from pin 1 being wired to positive and pin 2 to ground, the other thing I noticed in the relay schematic was that the load side of this relay is not electrically isolated from the primary as it is in almost all other relays that I know about. For that reason you can't bench test this relay without putting supply voltage on both pins 1 and 4, with pin 2 grounded, otherwise the relay won't fire. I verified this by testing the SMP relay I got earlier from ebay, using alligator clips hooked up to the battery, and the good news was that it doesn't seem to be damaged by the reversed polarity I had it plugged into earlier. Even though it's not actually a solid state relay there did seem to be about a 1v voltage drop.
As a side note, Rock Auto sells the RY-111/Rostra 600226 as the replacement part for both the EEC and fuel pump relays. I pulled out the fuel pump relay and on my vehicle ('87 XLT) it too was wired with a trigger on pin 2. So using the RY-111 or an equivalent as a replacement for the fuel pump relay without switching wires 1 and 2 would probably create the same problem. The fuel pump relay on my truck was the original green Ford relay, and it seems to have no extra electronics except maybe a resistor or flyback diode. I tested the resistance between pins 1 and 2 and it shows about 65 ohms going either direction.
Seems like there should be an application note somewhere about a situation like this but I can't find one.
I'll probably replace the relay socket rather than continuing to cut and paste on the old one. Should know soon whether switching the ignition and ground wires solves the problem.
The only time that should matter is in a simple magnetic relay with a flyback diode or with that dumb electronic relay in your picture. This is an amazingly simple circuit and should work great with a common magnetic relay.
Do you have full battery voltage to the contact side of the relay?
Do you have full battery voltage to the coil when the ignition switch is in start or run?
Do you have a good ground (0 ohms) for the coil?
An update:
If I'm reading the diagram on that relay correct, it looks to show a timed delay circuit (delays disconnection of the circuit after the control voltage is cut), however the pinout on the relay does not appear compatible with the pinout descriptions you have in your 2nd pic of the connector...
Pin 1 (on relay diagram) shows a diode that is positioned in such way so that only a positive current can flow into it to control the relay (your pinout description pic says Pin 1 should be ground)
Pin 2 on relay appears it should go to ground (assuming the transistors are NPN-type, the relay diagram does not show the symbols clear enough to tell for sure), however your pinout description says Pin 2 should be "power from ignition switch"...
Pin 4 on the relay looks like it should be powered all the time, so "Hot all the time" may be correct here.
Pin 3 on the relay appears it would connect to another circuit to be powered from the "Hot at all times" voltage at Pin 4 when it is triggered (so "Voltage output" may be correct here as well).
According to this (and assuming NPN transistor), it appears that for testing these relays, you would connect 12V to pin 4, Pin 2 to Ground, and apply 12V to Pin 1 to trigger it. After removing the voltage from Pin 1, the relay should then disconnect after 6 seconds if that is what "6S" means.
On the truck's socket, Pin 1 should be "power from ignition switch", Pin 2 should be Ground, Pin 3 to ECU power, Pin 4 "Hot always".
Again, this is all just based off just that relay diagram. I don't have any '87 truck schematics on hand (that show the correct pin numbers anyway).
If I was to guess why the needed delay, it is to allow the ECU a chance to store learned engine running parameters (fuel trims, etc.) into memory before ECU power is actually cut off.
Hopefully that helps
Good point. I hadn't thought of that.
Thanks for coming in on this and explaining the schematic clearly. It looks like i had the basics of how to hook it up right, but I wasn't understanding the delay part at all, how it was supposed to work or why it might be needed.
I installed one of the "bad" relays (an SMP RY-111 from ebay, not the one from Oreilly's that had the schematic on it) as you said, and now I have battery voltage with the key on, minus about .5v, at pins 37 and 57 of the ECU connector and ground at pins 20, 40, and 60. And the delay works. So those relays, along with probably the Carquest RAA1271 and others, look like they're all basically the same.
This issue, and the rainy weather here during the spring, has had me stymied for months, unable to get a relay that worked and skittish about bypassing electronics directly upstream from the computer. I still have some checks to do before I try to start it, and I may need to move the distributor again, but getting the relay problem solved helps a lot. I'll post again here if it runs.
Thanks to all who came in on this and offered info and advice. The truck starts and runs (!!!), so the EEC relay seems to have been the main problem. Still some checks to do and issues to work out but I'm hoping to test drive it soon.
