That's perfect LWT! I was guessing that they were basically the same, but guessing is almost as bad as assuming sometimes...
Yes. You're right about that. Stupid branding...That's perfect LWT! I was guessing that they were basically the same, but guessing is almost as bad as assuming sometimes...
Also, I think the Ecotec is a gm motor.
Appreciate the replys!
The dreaded intake flappers! Tick tick tick tick tickthe 2005 Focus won't have the intake flappers.
does it have variable cam/valve timing?
the front timing cover will be different, FWD cars don't have engine driven fans.
YOU'RE AN INTAKE FLAPPERThe dreaded intake flappers! Tick tick tick tick tick
Note that the OP in that forum was in Brazil. He may not have been inquiring about the same engines that stan is inquiring about.
