- Jul 29, 2011
- Portland, OR
I started a thread about alignment but found out I have bigger fish to fry. Main symptom is significant shimmy going over potholes and some squeak going over bumps at slow speeds. Tires looked slightly out of alignment so I thought that was it so took it to a shop and found...
Findings
Ball Joints - MOOG K8560T (uppers), Mevotech Supreme MK8561T (lowers)
Struts - FCS 341568 (front), FCS 342472 (rear)
Bushings - ???
Findings
- upper ball joint play on the driver side front
- very bad shocks all around
- worn bushings on the twin i beams (pics below)
- rear passenger leaf springs are a bit tired (the middle one is not snug up to the top one)
- Do both sides of ball joints need to be done? (I plan upper and lower)
- Anything else I should replace while doing the ball bearings and I beam bushings?
- Is there a specific name for the bushings on the I beams? Pics from the mechanic below.
- Replace upper and lower ball joints on both sides
- Replace both i beam bushings
- Clamp separated leaf spring
Bushings - ???
