It was new in 1973. You know Rick bought those batteries on FB Marketplace. Got a good deal. 237 batteries for $7.00, plus a couple big coffee cans to store them in.
Hey hey hey! The batteries were new from Harbor Freight (about a year ago), but I also tried two or three other batteries and everything was doing the same thing.
And I would never buy coffee cans. I’m still working on ones that I saved 20 years ago.
You did use a new battery, right? It should have enough force to lift the needle, I did it with the speedo in a vise oriented like it would be in a vehicle I think... I can try again today on the non tach cluster I have...
No biggie, I’ll get it. I actually have a bench top DC voltage generator, but at this point, I don’t know if the original was correct, so I’m just going to have to play with it a little bit.
Restored the front end.
Update on the check engine light and funky idle. The vacuum hose underneath the butterfly was disconnected. Seems to run perfect in the driveway, but I haven’t had it on the road yet, but I’m 99% sure that was the issue. We’ll see.
Speedo calibration questions.
Before I pull the needle on the old speedo, a 1.5 V battery brought it to 40 MPH, and that’s where I set it on the new speedo. @scotts90ranger said when he did it, it was 42. I figure I’ll start there with a brandy new quality battery.
1st question: is anybody aware of a calibration chart? Charge that would show what the different reading should be at different voltages? I actually have a desk top DC voltage generator, so calibration chart with softball problems.
Now, when the school radar camera says I’m going 41 miles an hour, the speedo reads 34 miles an hour, so reads 7 mph low.
2nd question: would that mean I am reading seven mph low at any speed? Or am I reading 20% low at any speed? Question is, is the needle rise linear or proportional?
Assuming it reads 7 mph low at any speed: I’m thinking I’ll remove it, attach a brandy new quality battery and wherever it reads, simply pull the needle and set it 7 MPH higher, and reinstall. Yes/no?
3rd question: one Internet video (the guy didn’t strike me as an expert or as a rocket scientist in general) simply presented that if you pull the needle, and, with no power, you set it at zero at the restraining pin on the bottom, it knows where to go all by itself. For clarity, it was not a matter of letting it fade counterclockwise until it hits the pin, but rather actually placing it at the pin, so there is no downward pressure, no matter how slight. Yes/no?
As always, any at all input is greatly appreciated.
I won’t be doing it for a few hours. @Curious Hound understands that it will take me a couple hours to come to grips with the concept, and build the strength, to actually go to a retail store and buy a brand new battery that’s not on sale. It goes against every fiber in my being.
Hey. I have a gauge cluster on the bench, a pile of good batteries and a 12v regulated power supply already set up. I'll play with it in a little while. I'm about to have a meeting with a woman bringing me a new defibrillator battery. After that, I'll start your experiment.
Hey. I have a gauge cluster on the bench, a pile of good natteries and a 12v regulated power supply already set up. I'll play with it in a little while. I'm about to have a meeting with a woman bringing me a new defibrillator battery. After that, I'll start your experiment.
Eric,
I think you know I like you, and I consider us friends, and I think of TRS as part of my extended family. I completely understand your admiration for me, it’s something I’ve learned to live with all my life. But I have a concern.
As much as you must love me, I don’t think it’s a good idea to use your defibrillator battery to try and solve my problem with my speedometer. It’s just not that important. What if you damage that battery, and your defibrillator fails when you need it? Then I’d have to go through all the feigned guilt stuff. I always appreciate help, but I’d just use a Walmart battery or such if you feel compelled.
Second, I’d be careful about putting 12 V on the speedo. If 1.5 V brings it to around 40 mph, I would be concerned 12 V might blow it/burn it up.
Having said all that, I would be curious what the speedo reads out of the shoot if you apply 1.5 V to it.
@scotts90ranger showed me to contact to the top left and bottom right solder joints immediately around the speedo servo motor when looking at the circuit board side. That’s what I did.
In the video I saw, that guy actually made up Y connectors, and connected one to both top connections, and one to both bottom connections, but again, I’m not sure he knew what he was doing. The video did not inspire me. I couldn’t find anything else on the Internet that spoke to the actual calibration of the needle.
Be healthy, my friend…
I don't believe it's voltage based, from what I remember when I looked into it it's a stepper motor so depending on what of the 4 points gets voltage it should pull the needle to a specific location. I can try again tomorrow, tonight will be helping my brother with something or other...
The contacts in question are the 4 around the bell shaped thing by the two screws.
Well, that's fun.
1.5 volts
3 volts
7.5 volts (old smoke alarm battery)
It seemed to max out at 50mph. Read the same with 14 volts.
The more I think about it and consider how the stepper motor works, I'm wondering if a more accurate calibration would be obtained by applying 12.5 volts and aligning the needle to 50mph.
Probably, but I’m guessing the use of a AA is the sort of work-around if you don’t have a good source for 12.5 volts
Frustrating, tedious, but problem solved (I think and pray). And THANK YOU @scotts90ranger and @Curious Hound - without all your input and bench testing and images, etc., I’d probably still be scratching my head wondering why it doesn’t work.
I put 1.5 V on the old/no tach speedo and set it at 40. As I connected and disconnected the wires, it would come back to 40 MPH. That’s with the speedo sitting upright in a vice.
Then I put the new/tach speedo in the vice and checked it with the 1.5. Needle rose to 40 where I had set it before.
Remember, test drives through the school radar warning signs showed I was running about 7 mph higher than the speedo was reading.
Then, crazy time. I invested $11 in eight Ever ready energizer batteries, brandy new. I usually buy 24 for less than that at Harbor Freight. Anyway, as I was fiddling, after the initial check, neither speedo would climb sitting vertical. So I flipped them horizontal like I did the first time, but this time it was in the vice that held them steady.
Next biggest problem I had was my own shaky hands, not the best to use when you’re trying to set that needle precisely. Frustrating. When I got it where I wanted it, and I put the voltage on it. It would rise from the pin to just over 40. If you pushed it lower with your finger, it would rise to the same place. But if you pushed it higher with your finger, it would only come down to maybe 44. But it did it consistently. Then I tried it vertical and the needle wouldn’t rise. With the power on it if I pushed it past vertical, it would fall to the high side. Frustrating.
I put it back in the dash with a just a couple screws and I did the test drives past the school radar sign. I was still running 7 mph high. So I took it back out and went through the process again.
Since it was reading pretty consistently 7 MPH over, I applied the 1.5 V, looked where the needle was, popped it off and placed it 7 mph higher (after a half dozen shaky hand episodes). When I pushed it lower with my finger, it would return, and when I push pushed it higher it would come back to about 3 MPH higher. I was out of time because I wanted to see the cute little brunette one more time before I drove up to Carlisle, but I also needed a test drive the truck for other reasons. I was planning on doing the CB calibration now that I have my radio working properly.
So after a quick shower, I headed up the interstate about 7 PM. Due to the bad weather, the traffic was too congested to play CB calibration. However, when I was coming home about 11 PM, the rain had stopped and the road was fairly empty. But when I called out to the rigs next to me, no response. When I called for a radio check, two out of three times somebody would tell me my radio was working. So I tried about 10 times riding down the interstate, but I had no takers. Obviously, they were all simply intimidated by the Road Ranger and didn’t want to play.
So around midnight, and it had started to rain again, I went back-and-forth past the three school radar set ups not too far from home. Two said the speedo was dead on the money at 35 and at 42 mph, and one said I was reading 41 when my speedo read 40. Problem solved, huh Not quite.
When I was radar checking that last little bit, and I was down to less than 1/4 of a tank of gas, the “check gauges” light came on, also a new feature on this cluster, and the gas gauge went to zero. Then the gauge would come up in the light would go off, three times in maybe 20 minutes So when the rain stops this morning, I’m going to pull the cluster one more time and just check all the connections with that sub cluster, and put it back together. Either way, that will be the last thing I do, but now I’m planning on bringing the old cluster with me because I’ve become an expert at opening and closing the dash in about 15 minutes, and I’m going to need the gas gauge more than the speedo if it acts up on the trip.
BTW, side note: when I first got the truck and I went into the dash to replace all the burned out dash lights, I changed all those 7 mm and 8 mm hex heads to Phillips head screws. With a long bit and a short bit on the drill, I can get them all out in a couple minutes. I still kept the 8 mm hex heads on the metal panel behind the lower plastic panel.
But, hey, I’m still happy as a clam, and I really appreciate all the effort you guys put into this. Really. If we fool around with 30-year-old/320,000-mile trucks, we’re going to have bugs. It’s not life and death, it’s a hobby It’s all heading in the right direction and I’m looking forward to the show.
BTW, I assume you know I was joking about the defib battery….
I picked up a new antenna on Marketplace today. My old one was a magnetic center loaded Cobra that was missing the stainless whip part, so it wasn't the most useful for reception and I didn't want to risk transmitting on it. Driving back across Denver in traffic and then sitting in a parking that's 3-4 miles from about a 6 mile stretch of I-70 I was never able to get anyone to break squelch on my new antenna. Granted there's a mesa between the parking lot and most of that stretch, but no one responded on 19 at all and with the gain all the way up and the squelch all the way down I could only occasionally get someone to come in faintly on 6 or 11. With the old antenna I could hear a group talking in a truck stop a half a mile away so I know the radio works, and the antenna is a magnetic Wilson 1000 that the seller said once reached a guy in Georgia.
Besides the new antenna, the list of this week's work includes replacing my front speakers and I filled it up with gas after having to make an unplanned trip to Colorado Springs to help my roommate swap the fuel pump in his Chevy yesterday. An afternoon and $40 or $50 in gas later, because I had to borrow a pair of floor jacks and then run them down from Denver, I was compensated with half of a Little Caesers peperoni pizza of my very own.
I kept saying that the intermittent sudden cutting out felt like a loss of spark and not a fuel issue, especially since it revved out just fine even under a load. But after calling a mechanic friend he decided it was the fuel pump. 3 hours later he started it and it still wasn't running right. It also tried to stall if you slammed the doors or tailgate, kicked the running boards, or popped the hood. It wound up being a loose connector on the computer behind the glove compartment.
Anyway, I went to the junkyard Monday for the 40% off sale. One of my finds was a pair of aftermarket speakers from the rear of a regular cab 1994 F-250 that had the wiring adaptors.
I figured out why my speakers sounded bad. Foam? What's that?
Here is one of the new speakers plus all of the accumulated dirt behind the door panel. Most of the plastic tabs were broken off on the passenger side, but I'm not convinced that the driver's side had ever been off.
I had to glue up the speaker that I put on the passenger side because the foam was partially separated. I did that with one of the subwoofers on the towers hooked to my apartment's TVs, radio, and Bluetooth sound system and it's still holding. I used some random wood glue that was laying around but white Elmer's is supposed to work too.
Then I popped the rear covers off out of curiosity, and I discovered how I had any bass or decent sound reproduction at all...
[Somehow I didn't get a picture, but imagine some blue Alpine 2 ways in the rear. A different blue than that of my blue interior.]
I also picked up an ignition coil brick from a lower mileage Ranger for a spare, the vacuum elbow that's cracked up on my charcoal canister, a trip odometer reset button that I somehow lost before I could install it, and two pair of tow hooks to see if I could make one set work on my '94 without the fog light bumper. I wanted a receiver hitch, but one was welded on and the other was held on by 1" nuts. I brought my roommate's impact, but I only had up through 3/4" sockets and wrenches with me and it was far too tight for my biggest all/sixteenths wrench.
After a stint of interstate this afternoon one of my hubs was about 115 degrees and the other was about 135 on my IR temp gun. Both calipers were about 115. It's only been 2,500 miles, a couple of shallow water crossings, some pretty hard wheeling, and maybe 7 months, but do I need to inspect and repack my front bearings already?
Also, what are the opinions of Valvoline 75W-90 "Full Synthetic Advanced" for a limited slip 8.8 and a Dana 35 TTB with 200k miles on them? The limited slip works sometimes. My roommate got a quart for $15 and he didn't wind up needing it, so he's trying to pawn it off on me since both of my differentials need changed.
I also read a claim somewhere on here a while back that limited slip additive keeps it from chattering on curves but it shortens the life of the clutches by making them slip more. Is there any truth to that?
