2005 Ranger 3.0 fuel mileage
Featured Build Threads
Lakewind
Forum Member
South Carolina
Horrendous fuel mileage.....My 2005 Ford Ranger 3.0 was never a champ at fuel mileage getting 20 mpg on the interstate but its dependability and longevity made up for it. However, 26 years and 275,000 miles later my little dependable Ranger is getting 15.4 mpg @ $4.29 per gallon. Ouch! It's always been maintained. Has anyone had any luck getting their fuel mileage back? Could O2 sensors cause this? Any feed back is appreciated. I've changed plugs, wires, coil pack, electric PCV valve in the last 2 years. Fuel and air filters always replaced. 3000 mile motorcraft oil and filter changes. The truck runs perfect. It doesn't use or burn any oil.
I have heard that O2 sensors do wear out and tend to cause the vehicle to run richer as the wear. I'm guessing it's kinda like incandescent bulbs where they actually get dimmer as they age.
If it has a MAF, I'd spray MAF cleaner in it and see what you get. I've heard that can do quite a bit to restore power.
Yeah, new pre cat O2 sensor(s) and cleaning the MAF with MAF cleaner or electronic contact cleaner only, do not use brake cleaner or anything else. Those would be where I would start, O2 sensors start to put out less voltage apparently after ~10 years or 100k miles or something like that and with lower voltage it thinks it is running lean so will add fuel.
Upcoming TRS Events
Featured Ranger Based Vehicle
