06 Frame Repairs
rangerkip1
Forum Member
Wellsboro
PA - USA
Vehicle
Drive
Frame repairs in progress, I'm sleeving the rear of the driver's side rail. Doing a patch to the center hole near the shock mount. And just a square patch on the hole on top of the pax side rail.
I plan on following up with extensive rust removal, Rust-Oleum rust converter primer, then painting it with tractor paint.
Unfortunately my rear end is rusted too badly (4.10 open), so I am swapping in a temp 3.73 from a donor truck (seen In photo next to garage).
That might be the most swiss cheesed frame I've ever seen.
Just replace the back 1/2 :)
Grind out the 16 rivet connecting the front and rear 1/2s, (4 on each spring shackle, 4 on each side of the frame crossmember)​
Pick up rear 1/2 from wrecker (Have them or do it yourself cut the frame ahead of the spring shackle/cross member). Repeat the shackle/cross member removal.​
Bolt in the frame crossmember and spring shackles.​
reconnect all your bits and bobs (springs, box, bumper, etc)​
Ford has a repair guide for doing exactly this (for accident damage)
Its easy and safe.
Its easy and safe.
Awesome. I did look into doing this, but my frame really isn't that bad, it's isolated issues and the thickness is fine. I bought this truck to be a beater. So I'm going to repair the frame and treat/repaint it.
I'm going as cheap as possible. The parts truck (running and driving, but toasted body and frame) was only $350, so I'm probably doing an axle swap.
Luckily the front half of my frame is completely rust free
The rear frame is really that bad.
When the those who have been on the forum 15-20 years say they never seen a frame swiss cheesed like that its an indication.​
While I'm not going to be driving in PA any time soon, other on the forum are from there as are you.
The frame is engineered to:
Flex / not concentrate loads, so it doesn't fail do to loading/crack due to stress concentration​
Yet deform in a major accident, so the driver isn't severely injured.​
Is someone's life worth saving a couple hundred bucks? (Hardly more than a couple tanks of gas these days. :) )
Especially if the front 1/2 is rust free - which means you're probably going to want to keep it for a while.​
I would take a chipping hammer and go checking the frame over really good for soft spots. I failed to do that on mine initially because the front “looked fine” but really wasn’t. There’s companies now that make repair sections/caps.
Cheap and frame repair don’t exactly go together. There’s resources on how to do frame repair correctly.
I managed to find a good rear section in a junkyard for mine and swapped the whole thing. Then I had to do some caps/repairs/sectioning to the front. Probably should have checked it better from the start.
I've been on here since 2010 ish, but lost email accounts and the military took me away from the forum lol.
The frame is not as bad as it looks, I'm doing some pretty intensive rust removal and reinforcement, I also have a new (stock) spare tire crossmember, and a thick sleeve for the back of the frame.
Luckily this is just a beater for me, I bought it as a backup vehicle and a something fun to work on. This will never be offroaded or used for heavy towing lol.
I am building that garage by myself for the sole purpose of messing with my vehicles and working on stuff.
Truck: $1700
Running parts truck: $350
Parts: $750
Tools: $500 (needed new jack/stands/impact sockets)
Got all those darned rivets out. Had to go buy a new grinder and an air chisel to do it with any sort of ease. (I don't own a decent drill it set, so that's on my purchase list).
Did the frame inspection today, thickness is uniform except where the holes are, and surprisingly minimal loss from scaling corrosion. Some surface pitting, but that's the worst of it. So some basic patches will fix the problems I have.
Unfortunately my compressor died, so I'm on my backup compressor (which is crap), so I will be on hold for doing frame reconditioning for 2 weeks. (Need to save up for a decent replacement).
I did test fit the replacement crossmember, and it fits great. Unfortunately my sleeve has really bad hole placement, so I'll be buying drill bits and modifying my weld-on sleeve over the next week.
06 Frame Repairs
06 Frame Repairs
I got a new compressor, this thing sounds like a box of angry bees through a megaphone. However, with the hobo freight deal of 20% off, and that welder on clearance for $110, I got some new tools. (Compressor cost me $320 after discount).
I cleaned the back of the frame where I will be sleeving, this is important because it will be trapped inside the sleeve. I am currently covered in orange dust from cleaning the frame with a grinder and needler.
First 2 coats are Rust-Oleum rust converter, and one coat of black paint. I will be clearing off the weld areas with a grinder next weekend and weld on the sleeve.
Unfortunately my needle descaler died. In the middle of cleaning up the other frame rail it spat out all its internal grease into my hand and got a very angry. So I'm on hold till I get a new one.
Disconnected the battery and started with the rest. I'm pretty sure it's not the original engine, and all of the brake lines, including the abs unit, look brand new. Most of the stuff under the hood does.
Removing the gas tank next weekend, so I siphoned out about 11 gallons of gas.
06 Frame Repairs
06 Frame Repairs
06 Frame Repairs
Those aren't my favorite welder but I sported one for years as my only option and it was the dumber version without a contactor so the gun was live all the time... There's compromises to be made, I would only run .035" wire as I had the best luck with that no matter the brand... and you learn some bad habits in you get better penetration with lower wire speed since the voltage is high in general (hence the suggestion on bigger wire) which is the opposite of what everyone recommends with a normal MIG welder... I welded my mudflap brackets with one and they held up the rear part of the suspension on my '90 out in the sand dunes, didn't find out it was broken until the next day...
I have an older gasless campbell hausfeld, but I rather use stick than MIG. I have had it for almost 15 years. It's a pile of crap, so I got this one for $110 on clearance. At least the safety switch works when you stop releasing wire bahahaha.
I use to weld frames with the 20 year old campbell hausfeld my buddy had, also gasless, the problem is that you often hit your duty cycle going full pen, but you do what you have to do lol.
The only stick welder I could find at harbor freight was an inverter style. I would rather use an older transformer based unit (like the tombstones). And I only have 25amps to play with out there at the moment.
Luckily this unit is a 20 amp unit on high.
So low wire speed on high with 0.035 wire is the only way to go.
It's also going to be bolted together. So I'm extra not worried about it. This is the easiest frame repair I've done.
I got the bed and the u bolts off the parts truck, as well as the shocks and driveshaft. Unfortunately the 3.73 rear in the parts truck has the same rust damage as the 4.10, however it's only rusted down 1/32, vs the 5/32 on the 4.10.
I'm unhappy, but it'll be a good replacement until I finish rewelding my 4.10 axle.
I am working with a mechanical engineer to make sure my repair will be structural, I will update that in a new post when I start that project.
06 Frame Repairs
06 Frame Repairs
Upcoming TRS Events
Featured Ranger Based Vehicle
