INFO File Sharing! Anyone have any handy Ranger Related STL and DXF files to share?
Featured Build Threads
This here is that spacer that goes behind the cab body panels under the seat belt. I don't know the name, but each side of the cab has two and mine were brittle and shattered when I removed mine. These are the first things I've made.
Hoping Mods/Admin Makes 3D Modeling a Subforum... šŸ˜„
Edit: This file ended up being 0.08" too tall, so if you took this file before seeing this edit, you have the old file.
Here's the gauge bezel I modeled up and printed for my 98 ranger I used a set of Omega Kustom gauges from Speedway Motors.
You'll need a pretty big printer to print the bezel, I used an ender 5 plus and had to put it on the build plate diagonally.
  • File Sharing!  Anyone have any handy Ranger Related STL and DXF files to share?
  • Right Flange.stl
    Right Flange.stl
  • Left Flange.stl
    Left Flange.stl
  • Ranger Gauges 7.stl
    Ranger Gauges 7.stl
Something like that would be nice for my 94
It might be helpful, in this thread, if people would post a jpg, png or bmp image in addition to the stl files. That way, other users can see what the item looks like.
I've come across a company called PCBWAY that makes PCB's but also does 3D printing. For those of us looking for a solution but don't have a printer, these guys print in all kinds of different materials.
Very much yes, please!
Copied this from another area on behalf of Poodlepuncher. Expand the quote to see link to thingiverse.
Not sure where to post this, but I made a panel to flush mount a dual USB power port on the dash.
it snaps in place of the blank panel found on 2wd rangers. no modification or fasteners needed.
ignore the white color. I used cheap PLA filament for prototyping.
I will be printing the final version out of ASA (probably ASA-CF), to better handle the temps, and direct UV light found inside the cab.
Currently i have a single, and dual port versions available
the 3d models can be downloaded here
Upcoming TRS Events
Featured Ranger Based Vehicle
