Trinity switch
gungfudan
⭐Supporting Member
Mississippi
N/A
N/A
I installed an electric radiator fan in my Mazda b3000. Right now I have it running constantly when the vehicle is on. I had it wired to thermostat switch but it doesn’t turn on when the AC is on so that causes a problem with the AC pressure getting too high and possibly blowing the seal on the compressor. I’ve been doing research and found that I need to get a trinary switch. Has anyone ever installed a Trinary switch before? I can see that they have female and male primary switches to connect to either the dryer or somewhere else. Does anybody know a specific trinary switch that will fit.
not me. i have never even heard of that
It is a switch for your AC. You actually hook it up to wherever your high low switches. Mine is actually on the dryer I think or it’s called the accumulator. Anyways, it’s a three wire switch that allows your fan to turn on when the AC compressor is on. It seems that is the only way you can have a temperature switch and have it turned on with the AC compressor is on.
Here’s the website that I found the one I need for the truck. I would say that newer vehicles with electric fans usually have three or more wires my Mazda B3000 only has two because it had a belt driven fan.
Never hear of it. I just tapped into the positive wire at the compressor and used that to trigger a relay.
That's cool. I'll have to remember that.
Did you also run a wire from the temperature switch?
I installed a temperature switch in the lower radiator hose. My current setup is very similar to the tech article using the 2-speed Volvo temperature switch, except that I reverted back to one speed and I don't have AC any more.
So, similar but really different. The truck has evolved over the years. I also installed a fan cutoff switch in the cab so I can turn the fan off during deep water crossings - less stress on the plastic fan and it doesn't splash water up over the engine.
