Trinity switch
gungfudan
⭐Supporting Member
Mississippi
N/A
N/A
I installed an electric radiator fan in my Mazda b3000. Right now I have it running constantly when the vehicle is on. I had it wired to thermostat switch but it doesn’t turn on when the AC is on so that causes a problem with the AC pressure getting too high and possibly blowing the seal on the compressor. I’ve been doing research and found that I need to get a trinary switch. Has anyone ever installed a Trinary switch before? I can see that they have female and male primary switches to connect to either the dryer or somewhere else. Does anybody know a specific trinary switch that will fit.
not me. i have never even heard of that
It is a switch for your AC. You actually hook it up to wherever your high low switches. Mine is actually on the dryer I think or it’s called the accumulator. Anyways, it’s a three wire switch that allows your fan to turn on when the AC compressor is on. It seems that is the only way you can have a temperature switch and have it turned on with the AC compressor is on.
Here’s the website that I found the one I need for the truck. I would say that newer vehicles with electric fans usually have three or more wires my Mazda B3000 only has two because it had a belt driven fan.
Never hear of it. I just tapped into the positive wire at the compressor and used that to trigger a relay.
That's cool. I'll have to remember that.
Did you also run a wire from the temperature switch?
I installed a temperature switch in the lower radiator hose. My current setup is very similar to the tech article using the 2-speed Volvo temperature switch, except that I reverted back to one speed and I don't have AC any more.
So, similar but really different. The truck has evolved over the years. I also installed a fan cutoff switch in the cab so I can turn the fan off during deep water crossings - less stress on the plastic fan and it doesn't splash water up over the engine.
I should probably consider something like this.
Currently I have an e-fan in my Choptop. Since my temp gauge on the dash didn’t work anyway and I was trying to get it back among the living quickly I screwed the temp sensor into the intake in the stock position and just wired up to a three position toggle and an indicator light. That way I have where it will automatically cycle based on the temperature sensor, an off position, and an always on position. It’s only temporary until I can take care of some other things right now but I like the idea of being able to have the ability to do off or always on. I’ve also thought about rigging a timer so when I shut the truck off it will run for a minute or three.
So, it's fixed?
I have mine spliced into the compressor wiring.
The snag is that that is 12v, most temp switches just ground so you end up with two signals that are not really on the same page.
I have found these things but haven't tried one yet
I was searching on the Internet and I saw someone mention hooking up another relay for the AC compressor I’m going to do that instead of buying a Trinary switch.
