INFO Dana 35 TTB vs Wheel Bearings
Well how similar are second gen Ram D44 knuckles to TTB Ford knuckles?
Do the deal to a D44 knuckle swap but use Ram knuckles instead of Ford and then you have bolt on wheel bearings and are only custom shafts away from having something. :icon_twisted:
Looking at Rockauto quick it looks like the U-joint at the knuckle are the same size, just swap Ram outers onto the TTB shafts... :shok:
Brakes for the ram would bolt right onto the Ram knuckle, rotor wouldn't know any different, still has the 5x5.5 bolt pattern like a fullsize Ford.
Sounds too easy, I bet the knuckle has to be different. :annoyed:
That was kind of what I was getting at. I have no idea how similar they are.
The other thing I had in mind was using a unit bearing from a car with 5x4.5 bolt pattern (90's Chrysler maybe or Jeep D30/D44 parts - a TJ Rubicon D44 would have 5x4.5 bolt pattern but probably really expensive) that could be attached to the D35 knuckle and finding a rotor that would line up with the D35 caliper in its normal location. If you can get to that point, you still have to find a shaft and locking hub if you want one.
Wonder if you could use TJ Rubicon D44 knuckles on a D35.
Initial googlage shows TTB D44 and solid D44 knuckles are different, I haven't found what is different.
At least with the old school solid axle stuff things swap around between brands.
I still like the idea of the Dodge knuckles the best. Wheel bearing and brakes will mount to that, Dodge outer stub shaft would mate with the D35 inner shafts and everything.
One big kind of eh thing with a sealed bearings on a D35 is that would make it live and the shafts would run full time.
Now I wonder what it would take to get a D30 or later D44 unit bearing setup onto a 35 TTB,,,
lol, I was actually looking at the reverse for my '99+ Ranger: How to put Dana 35 or 44 spindle in place of the Unit bearing so the axles didn't run all the time.
Note: For all intents and purposes the D30 and RBV D35 unit bearing are the same (there are minor differences, but the bolt pattern and the spline count are identical so you may use the alternative on the trail to get you to where you can get the correct part.)
Also note, all Dana 44s are do not have the same bearings: for reference: Dana 28 has Timken Set 45 for both inner and outer; Dana 35 has Timken Set 37 again same for inner and outer.
You have Dana 44s with Set 37 inner and Set 45 outer​
You have Dana 44s with JLM104910/LM104949 inners and Set 45 outer (3/4 ton axles with 8x6.5 pattern)​
I haven't come across Dana 44s with Set 37 inner and outer, but it might be possible..​
Also Dana 30s have Set 47 inners and Set 45 outers...which would be an interesting subtle strength increase for the Dana 35 axle..
I wonder if you could get crazy and do something like a 30/44 unit bearing with the splines milled out and use an old style d44 outer shaft with the heavy duty 35 locking hub...
I thought about that, you would need a bearing/seals or something to support the shaft inside the bearing and you can't just swing into O'Reillys or whatever in the middle of nowhere and grab a new bearing.
Now that I'm reading a bit more about the Dodge stuff it looks like that is not going to work. They have the ball joints pressed into the C's on the housing as opposed to the knuckles. Bummer.
Edit - Jeep seems to be the same thing. Probably explains why it hasn't been done.
Wish I had come upon this thread a little sooner... There's a lot of speculating here
I had seen someone here mention before that they don't use the races that come in a new brake rotor, they use the races that come with the new bearings.
Correct.
This is a big part of why (if not the whole why itself) we see the number of problems we do on the D35... Brake manufacturers putting bearing races into their rotors (usually cheap chinese races too), but not providing any matching cones to go with them (and so has nothing to do with the actual spacing of the bearings).
Obviously this prompts people to source (unmatched) cones from someplace else, and well... We wind up here (and you can't blame the end users either... It's perfectly normal for one to assume since it's there, "it must be ok to use").
I always try to tell people to replace that race with one from a Timken or other quality brand bearing set.
In 35 years (where have they all gone?? lol) of working on these for myself and for friends, we've had exactly one bearing failure among us... It was a friend's rig about 8 months after he decided to take it upon himself to go have brake work done at a shop (brake rotors replaced, new pads, etc.). When I took things apart, sure as shit, the races said "CHINA" and the cones said "U.S.A.".
We put Timken SET-37s on both sides and no issues since (this was maybe 15 years ago).
All of our rigs are on 33-35" tires too.
So yes it is very possible to have the axle be reliable in its stock config, but you can't let the rotor manufacturers sabotage you.
Used to be common knowledge not to mix these parts... (that was one of the first things my granddad told me when I was barely a teenager working on my ATC-70) Apparently that has all gone out the window with the D35 (or maybe was it the D28?).
This picture is misleading (and a little annoying):
I don't know who took the pic or where it came from, but I know that it has been floating around on here and on the 'net for awhile...
That is completely NOT how the bearings are on the D35 (yes, they are closer than on a D44, but they absolutely are not right up against each other like that, they are separated by about ⅜").
If I had both a D35 and D44 spindle & some bearings on hand that were loose, I'd take a more-accurate picture, but unfortunately I have neither available at the moment. :(
But again the spacing is not the primary issue here.
On some of the comments about other stuff:
Locknuts and the washer (manual hub setup):
Lately I've been laying a small bit of weld on the inside edge of the lock ring opposite of the tab, then shaping smooth with a Dremel or similar tool.
Aftermarket washers (all that we have today I think) don't fit as tightly around the spindle as the OEM ones did 30 years ago. A little bit of weld tightens up the fit, forcing the tab to rest further down into the groove so that it can't ride up out of the groove as easily and damage the spindle threads (I always put the weld opposite the tab so as not to ruin the temper of the metal on the tab itself).
Then tighten the outer nut to 225ft-lbs (75 above book spec).
Water contamination:
I try to fill the entire bearing cavity with as much grease as I can when I grease them. Obviously the locking hub itself can't be packed full, but I try to fill as much void as I can. This seems to at least reduce (if not completely stop) water from getting in.
This happens because it is a sealed cavity (and can similarly happen to cartridge (D30 or SLA IFS) bearings too).
When the warm hub (from brake heat) gets dunked into water, the sudden cooling creates a vacuum inside the air space within, and that is what sucks water in past the seals.
The most common seal to be breached by water seems to be the axle shaft seal at the back of the spindle, but others such as the wheel bearing seal itself can allow water in as well.
Beyond packing as much grease in as you can, there's not really much else you can do (I don't see any good practical ways to vent that space to the atmosphere with a breather hose).
I completely forgot to mention replacing the outer races. It has been standard for me to always use matched bearing sets for so long that I rarely think about it.
Good idea on welding the washer. Thanks. I wish the outer housung had a bigger bore so that a normal tabbed washer could be used. I've tried. It doesn't fit unless you cut off all the unused tabs. By the time you do that, it's almost a "one time use" thing and defeats the purpose of the multi-tab washer.
:icon_confused:
I guess I'm not familiar with this "normal tabbed washer"... Got a link?
Not that I can use it, it sounds like... Just curious since the only one with tabs I know of for a D44 is this one with four tabs that actuate an auto-locking hub:
I assume you're talking about bending the tabs, there's no bending those...
These. They are re-usable. Notice the inside tab is bent to give more purchase in the keyway on the shaft. When installed, usually, only one outer tab lines up with a notch on the locknut. Bend it into the notch. Simple screwdruver to unbend it for removal. This is how that style of locknut is most often secured in machinery. It works between double locjnuts like our hubs and it can be installed between a locknut and a "something" in order to lock a single nut.
I didn't read through everything, but I think the spindle nuts working loose and letting the rotor rub the caliper bracket and contamination into hub was always my biggest issue. The nuts back off (likely due to the bearing spacing) and if you try to overtighten them the washer would spin unless I added weld to the tang for a tighter fit (similar to 4x4Junkie but I added to the tang and filed it back square). I dont know if they would work under a D35 lockout, but I use these on my D44 now because it doesnt require any high torque BS. Just set preload and lock it down with the retainer.
Stage 8 spindle nuts
I built a D44 outer setup for my buddy's D35 and he wheeled hard for years on 33s with no issues after that. He also drove 2+ hrs to and from the trails. The bearing spacing and the ability to run superior lockout hub style made a big difference.
We used the small pattern Bronco spindle on the D35 knuckle, then used DRUM brake D44 hubs (they have a different WMS offset) and put a turned down D44 rotor on the FRONT side of the hub which allowed use to use the stock 95-97 Ranger caliper. I think we had to shim the rotor out like 1/8" to center it up in the caliper bracket.
Ah ok, on machinery... Yeah I pictured something kindof similar to that, but never seen it on a D44.
That's similar to how they do it on some full-floating rear axle spindle nuts, they usually have wider tabs you bend over for securing a big hex nut.
A bit late to the discussion here, but yes my locking nuts on my Dana 35 are still working great, all these years and probably 40k miles later.
One issue with the Dana 35 hubs is maintenance and sealing; the rear seal that is in rotor is sometimes not even replaced when doing rotors/bearings, which allows water and dirt ingress. The other issue is the O ring on the locking hubs is lost which also allows water ingress. I rebuilt mine 40k miles ago and replaced the seals, o rings and did the locknut mod. No issues at all since then.
Another thing to consider is wheel offset. Many of us running 33's and such will also have wheels with 3-4in of backspacing, which places a lot of offset load on the hub. On my truck I am running wheels with 4.5" backspacing, placing the load directly over the bearings like with factory wheels.
FWIW I have not had much trouble with the nuts loosening up. I've seen it a lot....just not on my own vehicles. I don't go real crazy tightening the outer nut either - as tight as possible with a breaker bar has been sufficient. I've seen the pin break off the inner nut a few times and always wondered if it was simple metal fatigue or a symptom of the outer nut being too tight and spinning the washer into the pin to where it breaks off.
The tabs on the washer being too short is for sure a problem, and most of the spindles I have on hand have bunged up threads. There are some thicker inner nuts that can move the washer outwards...that's my usual fix.
As for grease: maybe more would benefit me. I fill the space between the races in the rotor, plus the space between the inner bearing and seal, plus whatever is in the bearing itself. I'm sure I could fit more but there are many people who advise against over greasing wheel bearings too. I can see merit in both sides.
