Front Fuel Leak 1993 Ranger 4.0 XLT Auto
I'm not sure if I need 5/16 or 3/8 I'm assuming 5/16 because it's a supply line.
You could assume. Or you could measure. The choice is yours. I normally opt for measuring.
I just spoke with a sales rep from Summit. Here's the part I need. This adapts to the original quick disconnect line. I'm not sure if I need 5/16 or 3/8 I'm assuming 5/16 because it's a supply line.
Fuel filter uses 5/16” on both sides and I think also the tank fitting of those. Return I believe uses the 3/8” flavor. I keep a few of both on hand just because.
I’m probably end up at my buddies place today or Friday, my AN stuff is currently there, I’ll try to get some information.
@Curious Hound @lil_Blue_Ford The reason why I'm posting this video is because I wanted to see how this part (photo below) will couple/interface to the original existing part of the fuel line in which I'm not replacing as of yet. Is this the correct fitting I'll need? I'm just double checking is all.
It says it does. I looked at those a couple weeks ago. I like that style because instead of the spring lock, it uses that slotted nut to tighten down on the lip of the connection. That seems a lot easier to deal with, in my opinion.
Yeah that style is really sweet. I was just wondering if thats the proper connection hookup, not sure if I needed male or female.
@Curious Hound Would I need both a 5/16 and 3/8 fitting for both lines, supply and return. It says I would, but both fuel lines look like the same thickness.
Most of what I have seen uses both sizes. Does the same removal tool work on both? If so, they're the same size. If not, the smaller is 5/16" and the larger is 3/8". Or just measure them and see if they're the same. You won't measure 5/16" or 3/8" because that is the nominal size of the inside of the hoses. But, doing a comparison will tell you if one is bigger.
That's a good point, I haven't removed those not so quick disconnect fittings yet 🤪 Most likely tomorrow,,, however when I find out I'll post it on the thread. Most of the fittings and the PTFE hosing came today, but not that latest fitting I recently found on Summit. I just ordered them, the 5/16 and a 3/8 EFI to 6AN fitting.
The costs for all of the fittings and the Evil Energy PTFE 6AN fuel line kit, which includes the top intake plenum gasket, came to aprox $135. Really that's not too bad....I'm sure if I brought this to an auto mechanic, this job would cost an upwards of $700-$1200,,,heaven knows.
I spent a pretty penny on doing each of mine. It was a good few hundred.
Those garter-belt spring lock “quick connects” that Ford used are dumb. You can buy both sides in AN, and both sizes, but honestly if you have a fuel line problem I’ve learned just replace as much as you can, because the rest isn’t far behind. If I’m not trying to mate to factory lines, I’d just skip the factory style connections all together. AN is a far better system. Threaded 37* flares everywhere. Simple. Comes apart with wrenches and comes apart every time. No fighting connectors that are only quick connect in name.
There are two different sizes of the Ford EFI garter belt BS things. I have the numbers somewhere. They are different from the fuel filter/pump quick connects that actually sort of quick connect. Of course there’s two different sizes of those too. I’d eliminate the Ford connections if I’m doing the rail too. If I wanted a connection in the factory location I’d do a simple AN connection. But I’d probably just run to the rail from filter/tank. Less connections is less chance of a problem.
Running from the rail to the fuel filter is a good idea. I'm surprised they didn't do it that way from the factory. I suppose later down the road I could go that way.
Which connection can I use if I wanted to go with both AN fittings to eliminate the stock quick connects. I'll have one soon, I'll need the other one. Do u have a photo?
I suspect Ford didn’t do it directly because the length would probably change depending on the motor. So for production it’s easier to just make the truck side all the same and put whatever length on the motor to reach it.
I can get some details today or tomorrow. Trying to get a bathroom back together today so I don’t know if I’ll have time but tomorrow will be fixing a car with my buddy and my AN stuff is there so if I don’t get to it today, I should be able to tomorrow.
Not to keep this thread in suspense, as I have been pretty busy this passed few days with other projects going on, mother's day etc, I may give a crack at it today, all the hoses lines etc came in. My next step is taking off the not so quick fuel line disconnect fitting. I may try it later on today.
Sorry, things went crazy with rain we weren’t supposed to get Friday and I left my buddies place without grabbing my kit or taking down any information
