C5 Transmission pan?
You can probably modify a C5 filter to work in a deep C4 pan.
Or you could cut some strap metal and make reinforcements for your pan rails and use a premium gasket.
Whatever you do, please don't use RTV- if that stuff ends up in the valve body it will suck.
RTV is a last-last-last- desperate resort for me.
Stellantis ain't Chrysler.
AND Chrysler ain't Jeep, and Jeep ain't what it used to be. Hardly matters- I'm referring to my 1993 model. So if you care to hop into your DeLorean and go back to the 90's, it would be Chrysler.
That wouldn't be too bad, Lee Iacocca was still around.
Good news and sad news.
The good: C4 Lubelocker gasket fits the C5 pan perfectly.
The sad: The C4 reinforcement ring from JBG is definitely not a match...
  • C5 Transmission pan?
If you have a good fab shop nearby they should be able to scan your gasket and make a reinforcement ring however wide it needs to be to fit your pan.
