C5 Transmission pan?
You can probably modify a C5 filter to work in a deep C4 pan.
Or you could cut some strap metal and make reinforcements for your pan rails and use a premium gasket.
Whatever you do, please don't use RTV- if that stuff ends up in the valve body it will suck.
RTV is a last-last-last- desperate resort for me.
Stellantis ain't Chrysler.
AND Chrysler ain't Jeep, and Jeep ain't what it used to be. Hardly matters- I'm referring to my 1993 model. So if you care to hop into your DeLorean and go back to the 90's, it would be Chrysler.
That wouldn't be too bad, Lee Iacocca was still around.
Good news and sad news.
The good: C4 Lubelocker gasket fits the C5 pan perfectly.
The sad: The C4 reinforcement ring from JBG is definitely not a match...
  • C5 Transmission pan?
If you have a good fab shop nearby they should be able to scan your gasket and make a reinforcement ring however wide it needs to be to fit your pan.
1/4 in flat stock and a CNC plasma table would make very short work of that. (And generate plenty of waste material...)
UPDATE!!!
Been dealing with fires at work and working extra hours for the last three weeks so I haven't had much time to do anything. However, I made a go at modifying the reinforcement ring with what I had...
As one can observe, the C5 transmission pan is not fully identical to the C4, and it has one serious hog of a corner, which has to be accommodated. On the ring, I marked where to grind, and it took about twenty minutes of grinding with the dremel, bench grinder, and finishing with a file to get the ring to fit the pan- and what do you know, it fits!!
There isn't a lot of room to play with, a few of the bolt holes are definitely not lined up the same.
1. Should I widen the bolt holes?
2. After grinding, some of the metal stuck to the pan side of the ring, basically welding to the surface. They're small bits and I can probably get them off with a little elbow grease, but could a little bit of this hinder the ring's function?
3. Also, I may need longer bolts, will this be a problem if I do?
I'd love for this to work.
Good job. I would slot the holes as needed. I'm not sure what you mean by metal bits, but clean it off with a file. Use longer bolts as needed, but make sure they don't bottom out.
Basically some of the sparks attached themselves to the ring.
Update:
Everything fits fine, I actually did not have to open the bolt holes any, though I don't know how I didn't get them to line up at first- guess it helped to walk away.
Does anyone have the torque specs for these bolts. I'll be danged, I have all these service and repair manuals and not one of them, not even my official Ford service manual shows the torque specs. For now I have the bolts finger tight in a star pattern, followed up to make them a little more snug. I did try to use my digital torque reader on one and the lowest ft-lb reading it will give me is 16.
