- Sep 18, 2021
- Old Bridge
- State - Country
- NJ - USA
- Other
- 2005 Jeep TJ
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- N/A
- Total Drop
- N/A
- Tire Size
- 31's
- My credo
- Sometimes you eat the bear, sometimes the bear eats you.
Thanks, is it possible that there are two fuse panels inside the Ranger. One is definitely under the steering wheel area where I located it. I don't know if I saw one by the passenger side area.There is a fuel pump fuse. It should be in the fuse/relay box in the engine compartment where the relay is. Usually, the best way to depressurize the system is to remove that fuse or relay. Then try to start the engine so it burns the remaining fuel without the pump running. There should also be a schrader valve somewhere on the fuel rails as a pressure test port. You could push the needle in that valve to relieve pressure. But that is sometimes messy if there is pressure in the system. With your leak, I doubt there is much pressure there, if any at all.
Should be the fuse I'm pointing at.
