06 4WD Ranger wheel and tire fitment
Featured Build Threads
Forum Member
Pittsburgh
Hey all. I’ve lurked around here on and off for years, consuming your combined wealth of knowledge on Rangers whenever I needed it. But it seems it’s finally time for me to start my own thread.
I’m looking to get new wheels and tires for my 06, and having a hell of a time understanding what will work and what won’t.
If you just want to answer my immediate question, I want to know if the wheels in this link (Vision wheels) with the same size tires (255/70R16) I have now will work for me with no issue.
If however, you’d rather educate me, which I’d appreciate, read on.
I do know that I need a 5x 4.5 /114.3mm bolt pattern, and that my stock wheels are 16x7 wheels with a 4.5” backspace with 255/70R16 tires.
My problem is that I’m not sure how offset and backspace work together, and how much backspacing I can have before it’s an issue.
Thanks!
even if they do fit they will suck the wheels inward a full inch. look at your existing wheels, can they move inward another inch? check the front while turning.
backspace is the depth of the back of the wheel. it is totally independent of the size of the wheel.
a 6" wheel can have 4.5 backspace, an 8" can, so can a 12" wide wheel. backspace basically ignores the front & width of the wheel.
a larger/deeper backspace pushes the wheel inward.
offset looks at the wheel mounting surface and compares it to the exact/imaginary center of the wheel.
that means 3 different wheels, 6", 8", and 12" that all have the same 4.5" backspace will all have different offsets because the middle moves.
Backspace is the distance from the back of the rim to where the wheel mounts to the hub face.
Offset is the position of the center portion of the wheel in relation to the center line of the rim.
For example, the wheels on a 1997 - 2001 Honda CR-V and 2019-2023 Ford Ranger have a +55mm offset. So the face of the center of the wheel is slightly protruding past the face of the rim.
Wheels on the early model Rangers typically have something like a 3.75 inch backspace and roughly a +12 mm offset, if I remember correctly. So the wheel has a dish to it instead of being flush or slightly protruding with the rim face. I may be a bit off on the numbers, but that should give you the idea.
Thanks guys! That was really helpful! I actually have a decent understanding now.
I can’t seem to find any used wheels around me with proper backspacing and the correct bolt pattern, so looks like I’m stuck going new. Opting for 16x7s with 4” backspacing, 0mm offset. Pairing with some cheap 245/75 tires to offset some of the cost haha.
Realized today (got a notification in my email about another thread) that I never posted a picture of what I went with. If either of you were at all curious way back in July…. First off sorry, haha. Second, I went with these.
Those look good.
Did you end up getting a different backspace and offset or did you go with a small spacer?
Those look good.
Thanks! I went with 16x7s with 4” backspacing, 0mm offset. The bore size was 83mm. There were disagreements on necessity, but I added those little rings to bridge the gap between wheel and hub.
I'm really liking the 16" wheels. They look more proportional to the truck. I love my mod wheels, but they do seem a tad small... 🤔
If you were closer to Central Virginia, I'm going to sell the stock aluminum 16's off my 2011 Sport in the next few weeks...
My sister in law does live up that way, but I'll need to get a new set of tires for mine before I can consider a future upgrade. I appreciate the offer, though!
These will come with a set of 1-year-old, less than 10,000 miles Cooper Discoverer RTX 2's...
When I pull them off they are getting posted for $200
All four wheels and tires.
I wish you weren't 10 hours away. Any saving would be eaten by fuel on that trip...
Oddly enough, my door sticker calls for that size.
My 2011 Sport 4WD came with the 16" cast aluminum alloys.
I just +1'ed the size to 265/75's
Yeah, the '11 got 16's as an option to "modernize" it, even though it was considered a legacy chassis by then. They didn't change gearing, just ran lower profile tires to stay close. Apparently the speedometer accuracy is just a general guideline and not an end goal. I have learned a lot about that kind of stuff lately.
Rabbit holes...
Upcoming TRS Events
Featured Ranger Based Vehicle
