2003 PCV Valve Question
Chico
CA - USA
Vehicle
Drive
Hello,
I have a 2003 3.0 that has a pcv valve with an electrical connector on it. From what I have read, electronically heated pcv valves weren't implemented until 2004. I am assuming previous owner had it replaced and whoever worked on it put the wrong valve in. However, on the off chance that this car has had some magic done to it, I was wondering where I might find the wires for the pcv valve? I have followed the wiring harness and I don't see anything loose or unplugged that would connect to it. I am about to order the twist-in non-electrically-heated pcv valve, but thought I would ask. I can't find much info online or in the Haynes manual.
Thanks!
Luke
If I didn't find the wiring and didn't have codes. I wouldn't worry about it.
