- May 15, 2020
- Age
- 71
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- Vehicle
- Ford Ranger
- 4.0L
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
Sooo, I wasn’t happy with just my 97 Road Ranger being dented, so I bent the passenger door on the 87 short cab yesterday, short bed Missing Linc. Not too bad, I’ll just fix it myself. Oh, and the bottom of the door panel vinyl is curling up, but the backing panel and the door in general are in very good shape. I was thinking of cutting a custom piece of diamond plate and putting it on the bottom 6 inches like a kick panel, or just cutting a piece of masonite with thin padding and a vinyl cover, and placing that on the bottom like you see in a lot of new cars.
If you haven’t been following, I’ve been running around in circles with the factory radio, and the factory speakers & locations. I still have the all new driver front speaker with all new wiring but no sound. There is no problem with the output from the four channels in the radio on the bench. And, in the rear, with the seats all the way back, you can’t hear either one of the new speakers in the OEM boxes the second you turn the ignition.
Our personal problem (me and Lincoln) is that with only the passenger front speaker working, I blow Lincoln’s ears out trying to hear the radio when I’m riding down the road, especially with the windows open. So I’ve been thinking of putting the circuits for the rear speakers into the doors with new speakers in the front/middle/rear of the door(s).
Considering all of this, I figure it’s time to fix the door, fix the door panel, locate some new speakers, and get it 100% in general. I’m looking for success stories and suggestions from all you guys on what I could do and what works well. Very important, three points I want to emphasize, in random order:
More facts: I bought two inexpensive speakers that fit in the dashboard, that had high ratings, but they turned out to be crap. So I need new dashboard speakers. But, I’m not sure I’m going to put them in the dashboard. A wedge on top of the dashboard might be an option if they’re small enough. What are the options for the dashboard? What options for front speakers if I don’t want to keep speakers in or on the dash, what are the options to move them somewhere besides the dashboard?
I’m thinking I will put speakers in my doors. My instinct is put them near the front of the doors, but I would like to know the options. Front, middle, rear? Should I move them halfway up the door? Or???
What about putting speakers in the cab behind the doors, behind the seats, above the seats, on the back wall, on the roof, where ever?
I am completely happy with the OEM AM/FM/cassette radio in the dash. I don’t want to put in a new radio. If I were to change the radio, I would want something that looks period correct with green backlights, like original to the 1987 truck. I hate glossy red/blue video screen neon radios in classic vehicles. Actually, let me correct that. The vehicle doesn’t matter, I pretty much hate those radios in all cases.
Also, I have a new, never used, 100 amp per channel (4 speaker) Sony Explode amplifier that’s about 12 x 15”, maybe 2 inches thick. It’s even red, which goes with the truck. I’m thinking of mounting that right in the middle of the roof. Let me offer that I don’t listen to the radio that loud, but I have found using a decent amp greatly improves the quality of the sound and music coming out of the system.
My first thinking is quality speakers in the dashboard, or wedge speakers on top of the dashboard for the front. Then speakers in the doors, or down low behind the doors on the cab frame, but high enough that they are not muffled by the seats. The third option being putting them under the seats, or high enough on the back wall that I could then balance them with speakers in the doors and eliminate the speakers in the dash, or use the dash and the back wall or a combination there of.
I’ve also had the thought of putting speakers in some kind of center console thing on top of the 6040 seat, but considering that armrest is Lincoln’s perch (or ivory pedestal, if you prefer), I’m pretty sure I won’t do that.
I don’t know if I mentioned it, but I’m cheap, but I drive this thing enough that I might spend a few bucks. It’s not getting any $300 or $500 stereo system. So who has done what? What has worked? What has not worked? What would you like to try if you had the option?
Final question, when providing radio/speaker advice, for fixing the door, please indicate whether you think your suggestion will work better with 50 pounds of Bondo in the door or with 20 pounds of fiberglass in the door.
Thanks in advance…
- Cheap
- Budget
- Cheap
Thanks in advance…
