Radio-speaker set up. 1st generation, short cab
Rick W
Lil Big Rig
⭐Supporting Member
TRS 25th Anniversary
Truck of Month
Atlanta
GA - USA
Other
Manufacturers factory tour, maybe big dealership tour
Vehicle
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
Sooo, I wasn’t happy with just my 97 Road Ranger being dented, so I bent the passenger door on the 87 short cab yesterday, short bed Missing Linc. Not too bad, I’ll just fix it myself. Oh, and the bottom of the door panel vinyl is curling up, but the backing panel and the door in general are in very good shape. I was thinking of cutting a custom piece of diamond plate and putting it on the bottom 6 inches like a kick panel, or just cutting a piece of masonite with thin padding and a vinyl cover, and placing that on the bottom like you see in a lot of new cars.
If you haven’t been following, I’ve been running around in circles with the factory radio, and the factory speakers & locations. I still have the all new driver front speaker with all new wiring but no sound. There is no problem with the output from the four channels in the radio on the bench. And, in the rear, with the seats all the way back, you can’t hear either one of the new speakers in the OEM boxes the second you turn the ignition.
Our personal problem (me and Lincoln) is that with only the passenger front speaker working, I blow Lincoln’s ears out trying to hear the radio when I’m riding down the road, especially with the windows open. So I’ve been thinking of putting the circuits for the rear speakers into the doors with new speakers in the front/middle/rear of the door(s).
Considering all of this, I figure it’s time to fix the door, fix the door panel, locate some new speakers, and get it 100% in general. I’m looking for success stories and suggestions from all you guys on what I could do and what works well. Very important, three points I want to emphasize, in random order:
  1. Cheap
  2. Budget
  3. Cheap
While in random order, items number one and three are the most important.
More facts: I bought two inexpensive speakers that fit in the dashboard, that had high ratings, but they turned out to be crap. So I need new dashboard speakers. But, I’m not sure I’m going to put them in the dashboard. A wedge on top of the dashboard might be an option if they’re small enough. What are the options for the dashboard? What options for front speakers if I don’t want to keep speakers in or on the dash, what are the options to move them somewhere besides the dashboard?
I’m thinking I will put speakers in my doors. My instinct is put them near the front of the doors, but I would like to know the options. Front, middle, rear? Should I move them halfway up the door? Or???
What about putting speakers in the cab behind the doors, behind the seats, above the seats, on the back wall, on the roof, where ever?
I am completely happy with the OEM AM/FM/cassette radio in the dash. I don’t want to put in a new radio. If I were to change the radio, I would want something that looks period correct with green backlights, like original to the 1987 truck. I hate glossy red/blue video screen neon radios in classic vehicles. Actually, let me correct that. The vehicle doesn’t matter, I pretty much hate those radios in all cases.
Also, I have a new, never used, 100 amp per channel (4 speaker) Sony Explode amplifier that’s about 12 x 15”, maybe 2 inches thick. It’s even red, which goes with the truck. I’m thinking of mounting that right in the middle of the roof. Let me offer that I don’t listen to the radio that loud, but I have found using a decent amp greatly improves the quality of the sound and music coming out of the system.
My first thinking is quality speakers in the dashboard, or wedge speakers on top of the dashboard for the front. Then speakers in the doors, or down low behind the doors on the cab frame, but high enough that they are not muffled by the seats. The third option being putting them under the seats, or high enough on the back wall that I could then balance them with speakers in the doors and eliminate the speakers in the dash, or use the dash and the back wall or a combination there of.
I’ve also had the thought of putting speakers in some kind of center console thing on top of the 6040 seat, but considering that armrest is Lincoln’s perch (or ivory pedestal, if you prefer), I’m pretty sure I won’t do that.
I don’t know if I mentioned it, but I’m cheap, but I drive this thing enough that I might spend a few bucks. It’s not getting any $300 or $500 stereo system. So who has done what? What has worked? What has not worked? What would you like to try if you had the option?
Final question, when providing radio/speaker advice, for fixing the door, please indicate whether you think your suggestion will work better with 50 pounds of Bondo in the door or with 20 pounds of fiberglass in the door.
Thanks in advance…
Sounds like you can pull, wrap and re-glue the vinyl to the back of the card. That would be the cheapest, too.
Another nice repair for worse damage is to find some light carpet (think bath mat) that is close to, or matches the existing carpet), wrap it on a luan wood panel cut to fit, and then screwing to the bottom of the door (the carpet knap will hide the screw heads).
5 1/4" inch speakers mounted in the door, towards the front, will give the best "basic" sound in a first-gen cab. In the factory dash locations, you can do 3" or 4" on adapter plates, but anything in the dash won't sound near as good as door speakers.
"Back in the day" full-range 5 1/4"s in the doors, and smaller speakers blocked with caps, or tweeters, in the dash would make a good base system. A radio with a 4-way fade (balance and fader) let's you balance the two sets, and the windshield will decently reflect the higher frequencies back toward you.
Fun fact: when the '83 Rangers first came out, there was only a central mono speaker location. We put door speakers in the early ones to pre-install stereos at the dealership. Soon after, the three speaker location dash panel came out, then later on the central mono location was eliminated.
Rear speakers are a can of worms. They really won't do much for a basic sound system, and they eat up what little behind-the-seat room a standard cab has. If you wanted a louder system, you're then looking at boxes or tubes for rears.
I actually prefer stock head units in my old trucks now, even though I worked as an installer back when these trucks were new, and I did a lot of high-end systems back then (think 8-track, cassette and early CD days). I wish that there were more options, for replacement basic head units that closer mimic the original radios' form and function.
I think that you (and poor Lincoln) would be happy with a pair of door speakers and two dash speakers (limited to mid and high frequencies) with the stock unit.
Rick, post a pic or two of your door needing repair, outside and inside, to give us a better idea of what you're dealing with.
  1. Cheap
  2. Budget
  3. Cheap
( I wish I had a dog to ride with me ).
I don't have AC in my lil' D21, so the windows are almost always down. Its a single cab. My dash is sun cooked and any speakers on or in the dash would suffer the same fate. All I have is a 4.25" speaker in each door and one of these for $60.
A Bluetooth head unit supplying sound. It's not Crystal clear audio, by any means, BUT it improved the overall sound and it doesn't take up a lot of room. Mine is mounted behind the Passenger seat. It came with everything I needed for a complete install.
Brilliant, I don’t know why I didn’t think of that one. Thanks. And I’ll get some more pictures up.
I'm not convinced. I suspect Lincoln is a head banger and wants you to turn it up to 11. Unfortunately I can't translate dog to confirm that.
My first truck was an 84 Ranger, a standard trim package at that, and it only had the two dash speaker locations. In all my years of looking at Ranger pictures I've never seen a first gen with a mono speaker. If a single or 3 panel setup ever existed, it would have to have been very early like 83. That said I have seen a few 1st gen Ranger dashes that had a third removable cover in the dash top like the speaker covers, it was offset from center and didn't have holes like a speaker grill. Maybe that was location of the mono speaker, but wouldn't think so with it being offset, and I've been told it was for some control module (4x4 maybe?) by people that had it.
I just thought about it, but what color are the door panels in Missing Linc, and manual or power windows?
I'll have to do some digging, but I may have an extra set of first gen door panels. Might be few day or week before I get a chance to look. Sinuses (I hope it's sinuses) have got me down right now so don't need to be stirring up the dust in the shop, and got a project I need to finish up first when I'm back on my feet.
Yes, the VERY early trucks had the mono-only dash. The first 1983 year models actually began production in January, 1982 and were at the dealerships starting in March of 1982. The dash panels in the early ones were single center speaker only, then they came along with three speaker locations very soon afterwards. Plates were blank if no factory speakers were installed (no grille holes).
I had kind of a unique perspective of this at the time. I worked for a car stereo company, but was stationed at a Ford dealership, which also owned the adjoining Dodge dealer, which also had Renault and Jeep lines. All of these dealerships were on a "preload" program, provided by the company that I worked for. This meant that every car on these lots got a stereo and four speakers, with the buyer typically having to take the stereo as part of the car purchase. These were aftermarket radios, that mimicked the look of the factory units. They cost less than factory units, so the dealership made more profit on each car sold.
In this capacity, I would have gotten my hands on any new models as soon as they hit the lots, to make sure that there would be no hiccups with preloading. So I know that the very early trucks had only mono dashes, which we hated because it was a lot more work to put speakers in the doors, especially doing a neat OEM-appearing job of it.
So you bet that I was one happy camper when the 3-speaker hole dash became the standard. Fun job, getting new vehicles before release and being able to take them apart (and getting paid for it, too- what a deal!). Otherwise, I slung the shit out of stereos and fours, for several years there. In fact, I bought my first Ranger, a new '85 "S" model, and two more afterwards, from this dealership while I worked there. The dealership ordered their vehicles without factory sound as much as possible, for this reason
Trucks that had Premium Sound, the amp lived in this center location, and at first you could access it beneath the blank plate, which itself ended up going away. Later on, monaural radio trucks stopped using just the one big speaker, and instead used the two in the corner same as stereo units (I don't know offhand when this change occurred).
My guess, is that as time went by and profits really stacked up, the Ford bean counters went with the cheapest "common denominator" assembly parts setup. At a quarter to a half million units per year, it was more cost-effective (and profitable) for Ford to run a "one size fits all" setup, parts-wise.
I have this image grab from an early sales brochure showing the one-hole dash:
(no antenna is interesting; without an antenna that should be a blank dash plate, and production units had a decorative plastic plug in the pre-punched antenna hole if without a radio) This must be an early brochure, and a prototype truck.
And these drawings from the Ford parts catalog:
The radio in the drawings is the 1983-84 version; single DIN came in with the '85 models.
Did they reuse the center speaker location for the transfer case shift module? That looks exactly like where mine was.
For the bottoms of the door panels, I bought a boot tray at Walmart that had a diamond tread pattern. Cut the sides off and cut it in half. Used one half on each door.
That works too.
Is that a 3D printed are rest? Where did you find that? It would be a clean looking option for all those that are falling apart out there.
Haha, nooooo….
I’m in no rush on it, I’m up against a couple real life deadlines and obligations, some lingering health and mobility issues, and a work deadline, so it’s just going to have to wait. I’ll reach out if it looks like that’s an option, but I think the ones I’ve got will work fine.
The actual backing boards are in good shape, it’s just a vinyl on the passenger door that’s curling up a little at the bottom. And with all the other “interesting“ craftsmanship I’ve done, if I just put a diamond plate panel, or maybe diamond plate facing inward so the smooth aluminum shows, and I cover it with carpet or vinyl or cloth or little plastic soldiers or whatever, it will be cool and interesting if I declare it’s complete, and it will suit the hell out of me
I have to pull the whole panel off, probably open a few holes in strategic places with the window up to bang the door out, reasonably to the original position, use a little fiberglass, probably to mend and cover the deep scratches, and then just Bondo the whole thing to get it as well done as the rest of the truck, which is far from perfect.
Good news about the rest oleum paint job is that if I can’t blend that door in I’ll just end up painting the whole truck, take two hours instead of one hour and it’ll look showroom again.
I also have to fold the carpet up around the outside and back of the driver seat and see why the seat is tilting, clean it up and patch it and whisper it and then rock ‘n’ roll!
I counted nine different little things. I wanna do to the two doors and the mirrors and the antennas, and a couple of things on the roof and in the eight pillars and the back pillars, so it will be a two or three day job, but it’ll solve a lot of silly problems and make it much more comfortably drivable when I’m done.
If I put the amp on the ceiling, I’m also going to add an LED, a dim one that faces forward to light up the switch panel, every switch on the switch panel in the front of the CB light up, but when you’re driving down the road at night, nothing is illuminated to get enough to know which which does what. So if I put the amp a few inches away for a bit towards the back, one a little too tiny 2 mm LEDs should be plenty enough flight to just see what’s where. When you turn something on, it has an indicator light, but there’s a selection in the dark when nothing is running.,
And always keep in mind whole thing is just a big toy, I’m not relying on it like some of you guys.
My go to for truck speakers on the cheap. Old home theater surround sound miniatures. Like the 3.5-4” self contained square block type. Easy to hide, decent sound, keeps them out of the garbage can. 1 decent sized rare earth magnet affixed to the housing with carpet tape. 1 roll generic speaker wire. You can easily stick 2 to each door w/o issues.
