Aces Killshot Fusion EFI Swap
Flushed it?
That was a mighty responsible thing to do.
In a previous life when I was building hydraulic hoses I would just blow them out with the shop air.
I know my compressor doesn't compare to that one but it the little rubber bits inside the hose didn't seem to want to get blown out this time.
I really don't want them to stick an injector since this is all downstream from the filter...
I got the main pressure fuel line installed between the fuel filter and the TB. Got a wild hair and test fit the air filter housing:
It cleared the throttle linkage but did hit the throttle cable bracket so to do it right I will need a spacer. It is very close to working and really looks seated from above.
I also noticed the TB doesn't have anything to engage the tabs on the air filter base to locate the air filter housing.
Keyed on the fuel pump to test it. Ran great until it started circulating and the pump quit. Checked the fuse and it popped so I put my tester on it and it was drawing 7.2A which explains why the 5A fuse popped. Stuck a 10A fuse in it and ran great...
I checked things topside all seemed well... but then I could hear fuel dripping down below so I killed power to the pump. It is leaking at the inlet to the filter. At first I was scared I was going to have to drop the tank because that is just behind the tank (front of the tank is about centered on the filter) then I just got to thinking in the shower I could remove the filter and move it ahead and pick on the hoses. If it is a issue with the seal at the fittings it should be easy to deal with. If its the hose connection it could get entertaining.
Looks a lot better than that little blue dust cover.
Blue dust cover is back on lol until I get that sorted out lol.
I need to do the fuel pump wiring and the efan wiring and get the coil in it. I feel like I have been saying that for two weeks but I keep finding these other little side adventures to do that are a time suck.
Thinking more about it and how quick it would boil fuel out of the carb... a spacer to help keep heat off the ECM and to increase airflow under that air filter housing probably wouldn't be the worst thing.
I tried the 1/2" thick phenolic spacer I have ran since forever, it pushed the air cleaner assembly into the firewall. I had a 1/4" thick Edelbrock one and it fit perfectly.
My fittings also showed up so I have the PCV and brake booster hoses ran.
It worked great loosening the clamp and sliding the fuel filter ahead. That fitting was loose. Tried the fuel pump again and noted it was not spraying on the fuel tank but it was leaking from above the fuel tank as well. Thanks to the bodylift I was able to easily reach in from the front, disconnect the pressure fitting from the pump and access. It was also finger tight.
I remember it was late when I built that hose but I honestly don't remember ever thinking "ok I need to go back and tighten these up" Honestly I usually wouldn't even leave it in unless it was ready.
Also wire wheeled and threw some paint on the coil bracket so I can get that wrapped up tomorrow night maybe.
Your helper hasn't developed good tightening torque yet. He's just too young and small. Ya gotta go behind him and torque stuff.
I would have been better off in this instance if he had been following me...
