2.3L ('83-'97) 93 ranger ac issue
Jfam4l
Forum Member
Alamogordo
NM - USA
Vehicle
Drive
Stock
Stock
18” off-road tires
Hello guys I’m wondering if anyone can help me here . I have changed out my old r12 condenser, compressor,ac lines and accumulator as well as the low side cycle switch as well as the relay. I also bought an auxiliary fan to cool the condenser… I can leave it idling for about 3 hours and the refrigerant doesn’t vent through the high side relief valve but as soon as I go for a 30 minute drive then idle for about 3-5 mins the relief valve vents all the refrigerant, I caught it one time with the gauges connected and it vented at 300psi. I got all my parts from rock auto with the brand called UAC and of course this year doesn’t come with a high side pressure switch only the valve… I notice that the pressure valve is a short bronze valve on my new ac lines that “according to online” supposedly uses r12 Freon. Would me getting the r134a relief valve from a 1994 ranger prevent my valve from venting
I'm kind of confused. It sounds like you replaced all your A/C components like-for-like, retaining R12. So no, you shouldn't mix in an R134a relief valve. Generally, the appropriate response to venting pressure isn't to increase the pop-off pressure of the relief valve. Is the appropriate response to tripping breakers to install a bigger breaker on the same wire?
You need to figure out why you're over pressure. If you replaced the entire system, the options are bad parts, overcharge (refrigerant or oil), or undercooling (in spite of your aux fan).
If you spray mist the condenser with water as soon as you park, does it still vent?
When I turn on the truck and leave it idling for 3 hours without driving, it did lower the pressure to 125 when spraying the condenser. when idling without spraying the condenser it usually sits at 150. but the issue is when I go for a 30 minute drive then stop and idle for 5 minutes it raises up to 300 which I’m assuming triggers the r12 rated safety valve… everything in the system is rated for R134a I don’t know if the UAC Ac line that I got from rock auto has the r12 relief valve or R134a which is causing the Freon to vent at 300psi. Or if it can be something else causing it . I bought an auxiliary fan to help as well which is does, but I’m assuming it’s normal for R134a to reach 300psi? But to be honest I don’t know too much about A/c system…. but I made sure I followed the instructions to install all these components.
Okay, so you're not using R12, but converted to R134a? Then yeah, it's a problem if you still have an R12 line. It's not night-and-day, but R134a runs higher pressures than R12. An R134a system isn't venting at 300. The high-pressure cutoff doesn't open until over 400.
I would not try to replace the brass valve; I would replace the entire line and install the high-pressure cutoff switch as well. It just runs in series with the low-pressure cutoff.
Okay I will try that and see how it goes
I replaced all the parts on my 93 2.3 l ranger unfortunately the ac system got trashed by my stupidity and I had to buy everything new rather than just flush it I also bought a high side pressure switch which I didn’t have before. Before I attempt this again my sticker says max 2.5 lbs of r12 for a standard 2.3 l which I thought 32oz seems a lot for a small truck? Is that the correct amount of refrigerant I should add? I added 24oz perviously…. Also for the pag 46 how much does the system take it’s just hard because I see everyone online having different answers which confuses me.
  • 93 ranger ac issue
Dude, what system are you trying to build?
Is there R12 or is there R134a in your truck right now?
Okay, so don't take anything from the R12 system as gospel anymore, including the stock charge. Someone with more R12/conversion experience might be able to list exceptions, but generally you want to be using parts and information from 1994/R134a now.
R134a refrigerant charge is 22oz, per both my sticker and my 1994 manual. Although for such a simple system, I can't say I've ever weighed the charge in. Especially with modern self-sealing cans, you probably can't just leave them sitting there on the scale and expect good flow. IMO it makes more sense to just add until pressures are right, and the air blows cold.
Also per the manual, oil charge is 7oz, all in the compressor. New compressors should ship full of oil, and any reused old parts (evaporator?) will retain some oil. The amounts given for replacing one component at a time are:
Evap: 3oz
Condenser: 1oz
Drier: Whatever's in the old one +2oz
Okay perfect thank you sorry for the confusion . I will get it done tomorrow and see how it goes . And everything is brand new the evap,condenser and compressor
When the entire system is brand new, you shouldn't have to worry about the oil.
Technically I'd still drain a new compressor, make sure it's got the right amount, and possibly replace it with my own oil if it looks weird, but since you were already running the new system, that ship has sailed.
I drained 6oz of pag 46 from the new compressor and added fresh 6oz back to the compressor I also have 1 oz in the accumulator I did a vacuum on it and it held I still haven’t charged it. I had to go to work I wired a high side switch to the high side port using a t fitting I wired the two wires from the switch to the 12v wire from the compressor clutch . I’ll keep you updated once I charge it tomorrow
Sounds like you've got a solid handle on the process. But, if I understand you correctly, you tapped the high pressure cutoff into clutch power? It wants to be in series, so clutch power cut and each leg of the switch pigtail attached to one side of the wire.
Stock, clutch power goes through the low pressure switch, then high pressure switch, then WOT relay. The exact order of the 3 components shouldn't matter, but you do want them all to be before the diode, so make sure you're not grabbing the wire between the diode and the clutch.
Correct that’s exactly what I did each wire from the switch connected to each end of the cut 12v wire from the compressor clutch
And yes they are before the diodes reaching the compressor
