The 4.0 OHV frozen-in-place cam synchronizer saga continues…
Today I spent 3 1/2 hours not removing the cam sync. I don’t want you to think I’m feeble. I didn’t spend 3 1/2 hours trying to do the same thing, I spent about an hour each on three different things that I proved didn’t work at all. So now, I’m in the same place I was two days ago.
First thing I did was try channel locks, pipe wrench, you name it. I have two or three things that will fit on the new sync, so I know they will grab, but there is no room around the old one to get the jaws in place at all, and there is no room to swing a tool if you could get it on there. Failure.
So then I moved to my “claw, slide hammer“ thought. I took a piece of bed frame, because the steel is very hard, and I need small fingers to get around the thing, so any kind of malleable iron would just deform. Under the two screws of the sensor cap, it’s almost like it has “ears” that are flat on the bottom, so that would be an excellent grab point. I cut out a notch in a one 1-1/4 angle, but I didn’t cut it down to the fold. I let my two cuts end about 3/16” off the other side. I snapped off the flap with a crescent wrench, back-and-forth quick fatigue failure. Then I used a grinder to make a belly in the remaining piece.
I made a shaft out of 1/2” bed frame angle. I had to bend the shaft backwards and then forward so I could put it on where the manifold overhangs the thing. When I sliced off one side of the smaller angle, I again left about a 1/8 inch riser to maintain as much of the stiffness as I could. My plan was to drill a hole through it at the right height, slide a piece of pipe or square stock over it, and run a bolt through it to use as a slide stop.
There was not enough room to slide the two claws under the ears. I started to grind on it to narrow it to see if I could wedge it in, and it was very quickly obvious I was going to grind the claws off before I could ever get it in there. Failure.
Then I had the idea to make a similar contraption that would catch only under one year. Like a prybar, but with the tip facing backwards to use like a hook. Again, I’d make it a slide hammer thing. Using the same 1/2” bed frame angle, I cut a 2 inch piece, and welded it overlapping one end of the angle, so I could then bend it out the top, so I would have an edge that I could catch under the ear as I try to bump it up with the slide hammer.
Once again, I had to slice off about 6 inches of the shaft on one side so I could angle it back and angle it forward to reach around the manifold. I fiddled with that for a while, still no chance of actually getting it down in there in a place where you could grab that ear. Failure.
Sorry I’m at a loss. I’m contemplating writing a tech article for TRS on all the different ways you can’t get the thing out of there. Is there a humor section in the tech section?
After I quit and came inside, I did have the thought that I might be able to put a screwdriver or prybar across the top through the slot that aligns the cap. One problem with that is if I damage that thing and I can’t get it out, then it’s going to get towed someplace. Right now, if I just put it back together, I can drive it at 30-35 miles an hour to whomever might be able to help me with it.
I saw two videos where this was done. You can’t see the thing at all, you have to simply feel for everything you’re doing, and my ham hock hands, barely fit back there. I’m starting to realize I probably have to pull off at least the upper intake manifold simply to have better access. But the thing is actually half tucked into the lower intake manifold, so just taking the top one off may just be an exercise in labor with no results. And from everything I’ve done, I’m still not sure if there’s a way to grab it even if you take the lower manifold off.
I’m still waiting for those comments on how to do it. Speak up if you have an idea.
Rick, You’re in Atlanta where stuff like this isn’t supposed to be all rusty and stuck in place. We’re supposed to make the northern guys envious of how easy it is to work on our vehicles. I’m disappointed in you. I will admit that on my 3.0l, it is in the back and very difficult to access, also. But I replaced mine a few years ago. Don’t give up. You can do it. Have you dribbled any penetrating oil around its base? Can you get a soft punch or bar (brass or aluminum) down on its base and tap the punch with a hammer? Mechanical agitation can be a wonderful thing.
View attachment 140425View attachment 140426View attachment 140427
View attachment 140428View attachment 140429
Update, so I’ve been calling around to mechanics I know. I’m a pretty good shade tree, but I don’t do it for a living. Well, I’ve got a buddy who’s also a shade tree, but he’s a shade tree under a towering oak. I’m a shade tree under a weak little pear tree.
It’s surprised me. He said to pour brake fluid around it. He said the chemicals in the brake fluid will eat through the crack down to whatever’s holding it overnight or within two days. Of course I’m going to try it. The brake fluid can’t hurt anything down there like the paint.
Any thoughts on that?
Or, the most famous mix of all - 50/50 acetone and ATF
I’d say bring it to me and I’ll get it out but I’m kinda a really long drive, lol.
@Curious Hound nailed it, you’re not supposed to have these corrosion issues that we do. I’m not exactly sure how I’d get it out, but it would come out if I had to pull the motor to make it happen. I’ve only ever pulled distributors and the cam synchro on my 5.0 in the vehicle. The only 4.0 cam synchro I’ve pulled, well, the engine was on a stand with the intakes off so I had a pile of options. That’s also when I discovered that there’s like 5 different cam sensor/synchro possibilities for the 4.0 depending on year of the block and stuff.
I got the windshield replaced with an OEM windshield with the Ranger logo on it. A few weeks ago some tools fell off the back of a truck and one of them hit my windshield. I called the company to let them know about it and got a lot of verbal static from them. My last words were, "hey, I'm just letting you know you should consider letting the drive know about it because, if one of those tools kills someone and they have a dash cam, everyone involved is going to have a really bad day."
Finished putting the driers door back together on the '90, the window works great now! Annoyingly the duct tape I used to hold the window up is at the end of it's life as it left almost all the adhesive behind in 3 days... noting some acetone and a fresh razor blade can't fix...
Then I switched to cleaning out the solvent tank/parts washer so I can use it... annoyingly the dip hole that used it before had never heard about scraping the solids off into a trash can before going to the tank... there was 1.5" of sludge at the bottom... I found a screwdriver handle pry bar buried in it (handle's green, don't know if it's cool or not yet) and some random steel pieces... all together I have about 3 gallons worth in a bucket of just stuff I scraped out! There's less than a gallon of liquid left and a quart of thicker goo that I can't scoop out because I've monkeyed with it too much and it's dissolved some. It's cleaning up ok though, glad it was cheap but worth the labor? Jury's still out...
I converted the warning lights in the middle of my gauge cluster from incandescent to LED bulbs.
i found out my 24 ranger appears to have an agm battery instead of a lead acid. who knew?
Likely due to the power management system.
It is more so I can make them do what I want and not what the printed circuit board that is part of the cluster tells doesn't tell them to do. Currently how they are designed to operate they never will in my truck's current configuration.
Basically I did more bulbs because I would like to get the 4wd indicator lights to work down the road. Right now I can go ahead and get the bulbs in and run wire a ways in the dash so they are prepped when I circle back to that. I will probably have to use magnetic proximity switches on the levers as my transfer case has no provisions for a switch of any kind (and has been modified from how it shifted originally as well)
