2.3L ('83-'97) oil pressure on new rebuild '97 2.3
Turner
OR - USA
Other
Ford f350 cclb
Vehicle
Drive
Stock
Stock
Stock
I have recently had a short block rebuild with a reman head. I can not get oil pressure to show. I've installed 2 different sending units and now have a mechanical gauge. The builder used the original oil pump ( said they weren't available to them) the head was purchased through Autozone, this is the 2nd head, the 1st one had issues with #1 cylinder valves. I've checked and double checked the timing to be correct. The only thing I can come up with is something didn't get a plug internally. Any assistance would be greatly appreciated.
Have you pulled the driveshaft for the oil pump and checked it out? When you do not have a distributor, you have this dummy shaft driven off the camshaft that turns the oil pump.
Thank you, I have not, yet, I'm just trying to get some insight before digging to deep.
On a '95+ the oil pump is directly driven by the aux pulley, there isn't the oil pump drive gear like there was on the '83-94 engines. I've yet to dig into that style, my '97 seems to be working currently so I haven't messed with it...
I would be tempted to pull the timing belt and put an impact or drill on the aux pulley bolt and turning it to see if you can get any oil pressure, if not there might be an issue with the pickup tube which I don't know how works on those...
Thank you. I've thought of trying that.
Thanks for the correction.
