Swap Radiators
Wallers in rivers
💻 TRS Socials
Frankfort
IA- USA
5.0L
This is a pretty big issue with an engine swap, what are ya running?
What do you have for an engine?
What temp thermostat?
Hose setup?
Belt System?
Fan Setup?
Impressions/issues/thoughts?
Pics are worth a thousand words and part numbers are worth 10x more...
Hose setup?
Fan Setup?
What are ya running:
HD two row radiator for a 91-94 Explorer with A/C and automatic transmission
What do you have for an engine:
1987 CV 302, Mustang HO cam, shorty headers, 4bbl Edelbrock 1403 (500CFM) Shortblock is smilar to a '86 Mustang GT but without forged pistons.
Swap Radiators
What thermostat?
OE spec 195* thermostat
Hose Setup:
Cut and trimmed 4.0 Explorer upper hose.
Swap Radiators
I believe the lower hose is from a 5.0 Explorer, cut with a splice.
Swap Radiators
Swap Radiators
Belt system?
95-01 Explorer
Swap Radiators
Fan setup?
Low profile flex fan
Swap Radiators
And two A/C condenser fans for a Mercedes C230 Kompressor for pushers
Swap Radiators
Ok. i was going to start off with a smart-a** answer since you and I began discussing this last night. Instead, I decided I could stand to learn something. Based on what the Navy taught me about heat transfer and fluid flows, I would say the article linked below is spot on. It doesn’t tell you straight up “Use this radiator for that engine.” But all the clues are there for someone to make an educated purchase.
Note some of the things mentioned that we don’t often consider. The shroud is just as important as the radiator design and fan blade placement within the shroud - how far into the opening is the blade? Considering materials, I would aim for all metal construction. Plastic tanks won’t transfer heat as well as metal ones. Then all that stuff about how many rows, how many passes, fin density, etc.
For my V8 swap, I am hoping to use the OEM radiator from my Explorer donor vehicle. If Ford thought it was the right size, I’m willing to try it. I have a feeling that radiator placement, shroud and fan blade placement in the shroud opening will be the tricky pieces to optimize.
For what it’s worth, I had the stock V8 Explorer radiator in mine and never had any cooling issues whatsoever.
For my project, I will be also be utilizing an external transmission cooler in addition to the one in the radiator. I would like to use the oil cooler that came in my donor engine. But clearance to the power steering gear may prohibit that. Cooling engine oil should also help control engine temperatures. I firmly believe in cooling lubricating fluids and hydraulic fluids. I have already added a power steering fluid cooler on my truck.
Where the rubber meets the road here... is fitment vs performance.
OE is great where it fits... but it often doesn't. This is just to kinda share what everybody has tried and what works. The 5.0 Explorer radiator is a bit too tall for earlier trucks.
My plan will probably involve these
Swap Radiators
Swap Radiators
I used everything stock for a 1997/8 Explorer, which is what I stripped for my donor and it went in an 00 Ranger. I will say that I converted the fuel rail and electronics to a 00 Explorer but that’s neither here nor there for the cooling system really.
Dad’s 00 Ranger we used an 00 Mountaineer for the donor and everything stock for that.
One thing of note with mine was that I had tried a 180* t-stat initially and couldn’t figure out why it never really warmed up. Turns out even though it was brand new and not the cheapest and was stamped 180*, it was actually opening at 165* which was a lot of not good. It has a 195* now that actually opens at 195*
Yeah, somewhere down the line they became a lot more compatible with the 5.0 rad, I suspect it was around the '95 revamp when they went to a similar mounting system for the radiator.
I know that 98-11 are compatible with the Explorer rad. I suspect that the 93-97 may be compatible since they have the same style front end as the 95-01 Explorer, although it is possible that the 93/94 Rangers, being oddballs, may require modifications. I’ve never owned a 3rd gen Ranger yet though so I dunno for sure.
93-94 use the two floating pins at the bottom like a first or second gen so at least some modification would be required.
About 30 years ago a guy that worked for my Dad put a 289 from '66 Mustang in an '84-'85 Ranger and he used the same Mustang's radiator with minimal modifications. Mounts was all as I remember. There are lots of high capacity '65-'66 Mustang radiators to pick from these days. I plan to do the same with my impending swap.
I tried just the shroud, sitting about where I thought it would have to at the top it hung out the bottom of my frame. I mean it would fit, but I am afraid something would make its life short and painful offroad. And that was with a 3" bodylift.
So, to be fair, the 98-11 Rangers, even stock, the rad pokes out below the frame rails by a few inches. I was looking at my green Ranger yesterday and realized that
Y'all are gonna make me pull out my tape measure. Shame on you.
