97 2.3 lima Stock obd 2 turbo build
fredericksburg va
long time lurker, first post.
i have "Most" of the stuff for a turbo build with the exception of turbo. have 88 TC auto obd 1 ecu but for as long as ive been lurking here never seen the question asked as to what you would need to use the stock computer (97 obd2 ecu). im not planning anything earth shattering anyway and i under stand factory obd2 can handle low boost. so what would it take to run it? what sensors if any need added?what about the lost spark?have two cores one 87t one 96 na , 97 still running stock 2.3na 400k (+/-) miles.
Using the stock turbo computer is possible but would pretty much take the whole wiring harness for the engine to do it and converting to distributor and adding the vane airflow meter and switching a bunch of sensors...
You'd be best off with an aftermarket tuner or computer or something using the OBD II stuff... the '96 engine will have better flow in the head and such, the forged pistons should fit in the newer block assuming the bores are good...
I have enough stuff on hand to add a turbo and mild boost to my '97, it's on the list but pretty low, in like 3 years I haven't found the time to put in the rear slider window in...
yea im not looking to run the obd 1 ecu .ide like to run a stand alone obd2 style ecu but coin is an issue right now and i dont know crap about tuning ,so the cheaper options are out. if i can assemble the engine get it all plumed up and run it low boost off factory ecu ,well thats the question aint it? was looking for a 289 but i have the turbo parts and it dont cost anything to ask.
Isn't it pretty common to run boost with just a variable fuel pressure regulator? Seems like the easy button if you're looking for something passable.
passable is the name of the game, for the time being. so a higher flow pump? or injectors? both? i have the brown tops but their the old style (low imp?) i read some where at some point the yellow tops(v8 f150/mustang) can be used as a swap for turbo application. true or not i dont know.
From what I've heard you should be able to do about 5psi on the stock setup but I haven't tried it, yet... I've always planned on running maybe one size bigger injector but I haven't looked at what the flow rates are, it's either that or bump up the fuel pressure a little (there's some tricks I've heard of for this like adding preload to the top of the regulator in a press or something).
well im here to give her a try, have any idea the injectors i might be looking for? can i use the 8 plug head? or should i run the turbo head?(i'm assuming turbo&ground out the spare coil).is there a post or page that beat this horse? seems i have alot of digging & reading to get into.
The '95 up dual plug head flows the best of any Lima and has smaller valve stems, that's pretty much how it gained the last 10hp it did before gaining displacement to 2.5L... starting in '95 both plugs fired at the same time cranking or not so it's a wash, on my '90 I grounded the output for the drivers side coil so my tach would work but wish I'd stayed with dual plug... hind sight and all... There's just no reason not to run with both coils
I don't know the flow rate of the red '95-97 injectors or if they changed in '98 with the 2.5 when the fuel pressure was increased with the returnless system... For a really long time I ignored anything '95 or newer but don't you know it now I have one...
There are calculators online to help you figure out what you need for an injector. Stocks are 14lb/hr IIRC and they're barely enough to fuel a 2.3 in stock form. 5lbs is gonna need mid 20s lb/hr units at least.
so the turbo head is no different than the duel plug? good to know. didnt know they went to both firing thought the pass side fired on the exhaust stroke for emissions thought that might be "bad" for a turbo. well i am here to learn.
nice, not to be a needy assshole but can your recommend one? i have noticed my ranger "needing" a bit more fuel at times.
You need injectors with An EV1 body, jetronic connector, and they need to be high impedance.
Loads of factory Ford injectors from the same time period will be a direct fit.. just gotta find some that can flow the proper lbs/hr.
As far as how "big" you need to go.. It looks like 23lb injectors would be your bare minimum for 5psi and 27lb/hr would be the absolute upper limit. Under high load max boost situations the 23lb/hr units would (theoretically) be 95% maxed out, whereas the 27s would be sitting comfortably at 80% duty cycle.
Id personally aim for anything from 24 to 26lb/hr.
You need injectors with An EV1 body, jetronic connector, and they need to be low impedance.
You mean HIGH impedance, low is the peak and hold style like the original turbo Lima's, everything modern (for the most part) is high impedance...
Stock the fuel pressure regulator is vacuum referenced, that will increase the pressure with increased manifold pressure which maintains the injector tip delta pressure IE increases the fuel pressure to help with the duty cycle...
Flow wise the dual plug heads flow more, both coils fired at the same time, everyone over thinks the system, it's just for more complete combustion... yes it still fires on the exhaust stroke but that's just for simplicity sake as the coil packs just have two outputs so it fires 1&4 at the same time and 2&3 at the same time.
Whoop.. my mistake.. I shall edit that post for clarity.
As far as increasing the pressure.. how long would a stock pump be happy having to push extra psi?
