93 Splash in SC, V8-Swap version
So, I don’t think I checked compression numbers on my 5.0, but when I had the heads off because of broken bolts I decided to lap the valves and found that one hole, I think it might have been #7, had a poor seal on the valves so it was good that I did that apparently. Not saying for sure you have the same situation but it makes me wonder…
Today's progress. That's a heck of a job for one old man. Couldn't get the bolt out of the head that holds the dipstick tube. So I cut the tube. No big deal, except that I forgot to pull the dipstick out first. Oops. Lots of oil leaking from rear of transmission.
First time I did it I just left the tube with the engine... I forgot about that bolt, that bolt is why I have extremely long 3/8" drive locking extensions, should have bought wobble sockets then too, it's slightly more doable with the engine angled back some but yeah, no bueno...
I wasn't sure how easy the tube would pull out of the transmission.
Fair, if I remember right I found out by accident...
should just pop out.
That's what I assumed. But, to make it pop out properly, I would have the drop the transmission vertically. But I knew it had to move back horizontally before going down. Just wasn't sure how all that would work out. In hindsight, the results couldn't have been much worse than what I did.
step a
drill hole....drain trans for the drain plug kit you will be installing....
step b unbolt bell bolt.....yank out dipstick tube......plug hole.
this is all after step...1.4666-7/45-8
those are the steps where you have removed the core supports to both vehicles....
when you are old and your back is fawked up its just a wise investment.......its even better than when you were just young and crazy and lazy.
of course....had you done that...you would have easily pulled the powertrain out in one piece and really been able to yank on that sucker....put the smackdown on that no good dipstick tube bastard...
and drained it wherever was most convienient...
step a
NOW you tell me. :rolleyes:
move to my house......wait for the 15 minutes a month i get to go home....
this will go way mo better.
but really....trial and error is the best way....what dont kill you might make you stronger.....i heard of that happening to people...i think its a myth...it onle cripples me and makes me miserable...
pep speach of positive reinforcement of the day
Yeah. I'm considering core support removal much more seriously on the Ranger, now. That will make it much easier to sit things in place while I figure out engine and transmission mounting. Might also try to get the radiator a bit more forward. So, custom core support mods are in the works anyway.
This is all about learning. It's my first engine swap. Sometimes I waste time and energy trying to avoid doing extra work that would save me time and energy.
brother.....i have zero doubts in your ability to do this...and i wager i will learn some kewlz shit along the way.
i love watching and studying others approach and solutions to perceived issues.
so many ways to skin cats.....so few cats...
Dang it! What a day. The goal was to get the engine out. First fight was getting the fan clutch off the water pump shaft. Slightly challenging. But I won. Fan, radiator and AC condenser are out. Then I went through looking to see what else needed to be disconnected. The wind blew the hood shut. But it somehow jammed the first latch - the one you release with the lever in the grill. I fought that and finally took the sawzall to the grill and unbolted the latch. Next, I removed the upper intake. I know I'll need that out of the waybto loft the engine. Finally, I started unbolting engine mounts. Passenger side is easy access. I remived the bolts going through the mount into the block. Driver side? Can't do those bolts unless I remove the front differential. So I tried the big nuts on top that hold the top part of the mount to the rubber, or something. Still not easy. I got one. But the other is so close to tje block thst it's nearly impossible to get a breaker bar on the socket. Broke 2 crows feet. Finally got it broke loose. But it's loc-tited on. So every 1/6th of a turn is a fight. Finally quit for the day. As far as I know, that one nut and gravity are the only things holding the engine in there. When I get back at it next, I might just unbolt the diff and let it drop out of the way.
Todays carnage.
Someone was living here. I don't see any wiring damage nearby.
Upcoming TRS Events
