2.3L ('02-'11) 2001-2003 2.3L Intake Manifolds, Swap for 2004+?
King Of Mercia
Forum Member
Milwaukie, OR
There's a thread on here about swapping to a newer intake to get rid of swirl plates but the OP never followed up. Does it work?
My intake is getting the IMRC flapper rattle, and it's gonna need some work soon. I haven't seen a lot of success from people about dealing with it.
The intakes are all discontinued, so I'm trying to figure out where to go from here.
I've seen people cut out the flaps with mixed results. I'm reluctant to do that if I can't get a replacement intake.
Wondering if I can replace the intake with a later model one without the flaps. Apparently those intakes still have mounting points for the IMRC actuator and all, so I can attach those parts and just leave them there. Wonder if that will keep it from throwing codes.
Anyway. Anyone got experience with this? Or a Dorman intake 615-462 sitting around they'd sell me? Lol
Were you ever able to figure it out I’m wondering the same thing, just broke a bunch of the little pieces that hold the gaskets in.
Nope, no one ever replied. Like always when I post here.
Forum's mostly dead I guess.
I asked my shop dude and he said he didn't suggest it. Good luck with your intake. Dorman sucks for discontinuing their aftermarket one, 615-462. Leaving us all high and dry.
the intakes will swap between 2002 and 2005
I put a 2005 intake on a 2002 motor.
that 2002 motor is now in a 2005 Ranger so I did not have to worry about the computer missing the flap actuator.
the 2.3 Duratec motors are very reliable so posts about them are few in number.
my 2005 had 370,000 miles when I pulled it for oil consumption issues.
That's the big question for us 2001-2003 owners though, will the lack of IMRC cause it to throw a code constantly? Or will simply bolting the actuator on and having it not-actuate-anything, suffice?
Right until they aren't! Mine is being fussy right now with lean codes, and now a misfire on Cyl 4, and I can't figure out why. Replaced intake gaskets, valve cover gaskets, O2 sensor, MAF, and checked for vac leaks. Hoping the shop can help me get it sorted out this time around.
check plugs for oil on #4, do a compression & leakdown test.
my problems started when #1 rings lost tension, the rest of the engine was perfect on teardown.
I don't know if the computer checks to verify if the flapper actuated. how many wires going to it????
It's due for a trip to the shop but I will check compression in the next few weeks. Have wanted to for ages. Good idea!
In the meantime I made a post at the other place with some more detail, freeze frames and the new misfire code that popped up. And a video of the weird idle and high pitched sound.
Thanks so much again!
My problem is a vacuum leak at the actuator side of the intake manifold. It's all worn out right there. Need a new intake.
Can try to just remove IMRC and seal it but it's a permanent change. Concerned it'll run like shit, or throw a code. Then I can't pass inspection.
Anyone know how major the changes here are? I think it's just the PCV stuff attaching a little differently.
There is some follow-up on the other thread. One fellow deleted the flappers and shaft, epoxied the holes shut, and left the MIRC on doing nothing -- computer was happy. Another used a 2004 intake and had to make some changes for vacuum lines as the previous post here suggests. I'm going to be removing the flappers in mine and sealing...
That was me. Here it is:
Swapped it April 2025. Works great, no more issues at all. Fuel trims are perfect. Power is good. Gas mileage is the same as always. No stumbling or stuttering.
After 10 months it seems like everything is working normally now, the only change is that first gear is a bit anemic feeling below 1300 rpm when the computer thinks the IMRC is closed. (but it's open because it's not there.) It's not apparent in other gears, just when taking off from a stop.
Also the truck is much much quiter without the IMRC clicking and clacking and being worn out.
Found a good hood at the junkyard this weekend and replaced my dented one. Lookin' good! :)
Now I've gotta figure out how to straighten the bumper.
Should I take it out if it's working correctly now? I suppose so... the engine has 150K on it so I guess it's just a matter of time. I think you mentioned having over 200K on yours? I wonder if I'll have the same under 1300 rpm issue if the MIRC is programmed out of the ECU, since you left the MIRC on and connected...
Is there any advantage to using a 2004+ intake over removing the flappers and sealing the holes in the 2003? I'll be retrieving a 2004+ thermostat housing to ditch the heated electronic thermostat anyway. I know it might be less work, not really worried about that.
a word of caution about the flappers.
they have guides inside the manifold that contain/hold/positions the 4 intake to head gaskets.
those guides are extremely fragile and when they break there is nothing to hold the gaskets.
Thanks for that warning! I'll pull the intake and remove the flappers before going to the pull-a-part for the t-stat housing. Then if I break anything important I can pull a 2004+ intake also.
