PlumCrazy's 88 SuperCab 2.3T Build
I don't recommend using the brown top injectors. They are low impedance and are known for leaking with age. Racetronix is where I buy mine.
I've been on the fence with what to do with injectors. I see two of these injectors have different o-rings and tips on them making me think someone has been through this before. I will likely end up putting a fresh set of injectors in this setup eventually.
Dumb note just to be sure, not saying you weren't paying attention... I've ran into the oil pan situation and trying to remember what I did at roughly 10 years ago... I know in '86 the change to a one piece rear main was done which also changed between a one piece and 4 piece oil pan gasket, the one piece had a trough in the rear main cap for the gasket where the newer style was in the oil pan, I thought that lined up with the 6mm vs 8mm oil pan bolts in the back but thinking more I think I had to drill the replacement pan when I switched from a '85 block to an '86 block (uncle Rodney came to visit... he's a jerk).
I'm running brown top but mine's 100% stock computer and everything, I don't doubt they leak, I know my turbo shaft seal is shot and there's runability issues sometimes but hey... I'll get there eventually... if I change to aftermarket fuel system I would go high impedance injectors, they've come a long way in 40 years...
I filled the groove in the rear main cap to seal against the once piece gasket and swapped the front cover to the new style. I just over looked the block had large bolts in the rear still.
The more I think about it, the more I think I should probably toss new injectors in....I maybe I'll at least start with these because I'm a cheap ass.
Perfect, I ran that way for years...
It's probably easy enough to change injectors later... I think I got my injectors from a member a bunch of years ago...
The brown tops can leak from the side. Fire hazard.
High impedance injectors are much easier to configure with aftermarket fuel injection, and create less noise on the power circuit of the ECM...
Oh, fair, I haven't ran into that... the fuel guzzling on mine is all internal :). I'm used to the GM world and have ran into the low vs high impedance thing before, for the LS world there's all sorts of cheap options since the 6L's were E85 capable for a while and the LSA injectors are cheap too... if my '90 gets cranky sometime I'll go aftermarket engine control but so far my small VAM and LA2 are somehow working? I have a big VAM and LA3 floating around that's been "on the list" for a number of years...
I believe those are the squirters I used. It's important to select them with a pencil pattern (not cone) and buy from a distributor that matches them by opening times and flow rates.
I ran them with a MS version 1 and didn't experience any idle issues. The MS3 you are looking at has much better pulsewidth resolution at idle. You shouldn't have any issues with a big injector.
I'm planning to run these brown tops through the ultrasonic and see how they do.. Ill upgrade them if they give me any trouble. The base tune I have is for the brown tops anyway.
Well... weekend got derailed.
Sat the motor in and figured out the intake plumbing...but that's about it.
But took the black truck (SAS winter beater) for a few hour trip to snag a ZF swap for my buddy's new tow rig.
Flywheel, clutch, column, and driveshaft not pictured**
You probably already know this, but you'll be limited to about 10 psi without aftercooling...if you can scrounge up one from a Turbo Coupe it's better than nothing...
I am aware, with the manifold flipped the top mount IC doesn't fit. I have an 8psi wastegate actuator to start with.
Once I get the hang of playing with tunes and making sure the setup is mechanically sound I look forward to adding things like an intercooler, utilizing the boost controller, modern injectors, etc.
For what its worth, I don't have any desire to make a max effort setup. I just wanted to dip my toes into the turbo world and see how it goes.
I'd double check the pimpx can run the low impedance injectors. Most of the MS lineup won't run them without additional resistors (and even then it's not optimal). It's possible Stinger added that functionality however. My PimpXShift did NOT have that capability.
As far as tuning goes, you are much better off biting the injector bullet at the beginning.
Half whooped clutch is back in after fighting the pilot bearing out for nearly and hour.
Used my trusty old bent valve to lock the flywheel while I torqued everything.
My new trans holder 9000 worked flawlessly too
Trans installed after going through my slave cylinder inventory...used a master-slave hose I had on the shelf last time that didn't play nice with the 88 slave last go around without modifying the clip on the slave coupler. Found that the blue, gold, and black couplers don't all play nice with one another.
Snagged the crank pulley off of my backup 97 2.3 and trimmed up the water pump pulley from a 92ish mustang 2.3 setup to cleanup the accessory drive.
Been fighting some sort of allergy bug / sinus infection so progress has been slow.
But I checked another item off of the list. Got the wastegate actuator sorted out.
Bent up a chunk of 12ga steel (I acquired like 200 of these 4x6 coupons from work years ago and finally used one years later lol)
I used the old actuator mount as a template for the area that the clamps the compressor housing in place
Then had to get creative with the press brake because the bottom die needs like 2" of material on both sides and doesn't really bend past 90*, so i clamped two of finger dies together and used them as a bottom die.
Had to tweak the second bend a little more after adding a 3rd bend to clear the alternator
Trimmed the extra bits off and tweaked the actuator rod into submission.
Clears everything perfectly now.
Still didn't get a ton done today, but chipping away at the list none the less.
Mocked up an oil feed line to the turbo out of some filler wire.
Then made the real thing with 1/4" hard line. I'll still have to make a support towards the rear. Hopefully I can find an old spark plug wire support that mounts off of the valve cover bolt.
Also installed the radiator, shroud, fan, and hoses.
Made some rubber shims from some old baler belt to support the rad from the bottom.
Turns out it's basically been dangling from the flimsy upper tabs all this time.
Put fresh 1310 Spicers in the rear shaft, but unfortunately ordered the wrong carrier bearing, so I'll have wait for another to arrive.
Lastly had a buddy that TIGs far better than me weld up my exhaust v-band flange and wideband bung. I will trim to length once I see how everything lays out.
